Split configuration.yaml: binary sensor works, switches not!
I have some strange behavior with a configuration of relay over MQTT.
Struggled to get MQTT working, now it’s OK.
First strange thing: the MQTT integration doesn’t pick up the device even though it works.
Second odd thing with configuration.yaml:
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
#sensor: !include sensor.yaml
binary_sensor: !include binary_sensor.yaml
switch: !include switch.yaml
switch.yaml:
mqtt:
  switch:
    - name: 'relay16b-output1'
      unique_id: relay16b-output1
      state_topic: 'relay16/2154d5e0aa46831378722ee8/state'
      command_topic: 'relay16/2154d5e0aa46831378722ee8/set'
      payload_on: '{"relay1":{"on":1}}'
      payload_off: '{"relay1":{"on":0}}'
      value_template: '{{ value_json.relay1.on }}'
      state_on: 1
      state_off: 0
- platform: mqtt
  unique_id: relay16B-2
  payload_on: '{"relay2":{"on":1}}'
  payload_off: '{"relay2":{"on":0}}'
  value_template: '{{ value_json.relay2.on }}'
  state_on: 1
  state_off: 0
binary_sensor.yaml:
- platform: mqtt
  unique_id: relay16B-input1
  value_template: '{{ value_json.input1.on }}'
  payload_on: 1
  payload_off: 0
This way: the configuration checks OK, the input works but the output not.
If I add the switch to the configuration.yaml, the output works.
Out of curiosity: by adding a switch to configuration.yaml and still using the splitted configuration, will the switch.yaml be used by the system?
Your config is invalid. When you put a !include what actually happens is the contents of the file get shoved into that spot. So here’s your actual config after replacing the !include statements with the contents of the files:
binary_sensor:
  - platform: mqtt
    payload_on: 1
    payload_off: 0
switch:
  mqtt:
    switch:
        state_on: 1
        state_off: 0
  - platform: mqtt
    state_on: 1
    state_off: 0
See the problem? What’s under switch makes no sense. switch can’t be both a dictionary and an array.
mqtt is a top level key separate from switch. You have to re-arrange your config like this:
binary_sensor:
  - platform: mqtt
    payload_on: 1
    payload_off: 0
switch:
  - platform: mqtt
    state_on: 1
    state_off: 0
mqtt:
  switch:
      state_on: 1
      state_off: 0
Feel free to replace any chunks of this with !include and move them out into other files. But you can’t really put new format mqtt entities and old format mqtt entities into the same file, that won’t work.
Hi Mike, thank you for helping!
I don’t really get the problem… :blush:
Since it was not working, I tried the new format and saw that both ways are still valid so used them deliberately - but had no idea that they could not be mixed.
If I want to put these switches with the new format in a separate file, should it be mqtt.yaml and like this:
switch:
    state_on: 1
    state_off: 0
Example from my config:
mqtt:
  sensor: !include_dir_merge_list cfg/_component/mqtt/sensor/
  binary_sensor: !include_dir_merge_list cfg/_component/mqtt/binary_sensor/
  switch: !include_dir_merge_list cfg/_component/mqtt/switch/
sensor: !include_dir_merge_list cfg/_component/sensor/
binary_sensor: !include_dir_merge_list cfg/_component/binary_sensor/
cfg/_component/mqtt/sensor/boiler_temperature.yaml
  - name: "Boiler Return"
    state_topic: "building/dhjm/eobs/99031647c54fff28"
    unit_of_measurement: '°C'
    value_template: "{{ value_json['obs']['temperature']|float }}"
    device_class: temperature
    unique_id: onewire-cb6a6c2d-b7e1-4369-9088-dd559fd6e9e9
  - name: "Boiler Water Out"
    unique_id: onewire-fa42e7c4-1e87-4622-900f-75f517061933
cfg/_component/mqtt/sensor/ruuvi.yaml
  - name: "Patio Temperature"
    state_topic: "dhjm/building/eobs/ruuvi/d5ac310fd9d4"
    value_template: "{{ value_json['temperature'] | float }}"
    unique_id: ruuvi-5935f262-65ae-479c-a16d-5b499a5b341e
  - name: "Patio Humidity"
    unit_of_measurement: '%'
    value_template: "{{ value_json['humidity'] | float }}"
    unique_id: ruuvi-ab8ad083-5efa-48a8-9158-ae918aaf35d5
    device_class: humidity
  - name: "Patio Air Pressure"
    unit_of_measurement: 'hPa'
    value_template: "{{ value_json['pressure'] | float }}"
    unique_id: ruuvi-134288e9-af9f-464f-addf-2f89a0b4018a
    device_class: pressure
I hope that gives you a bit more of an idea of how to split the files up.
I’ll add a switch example too:
cfg/_component/mqtt/switch/fr_switches.yaml
  - command_topic: dhjm/rfxgateway/command
    optimistic: true
    payload_off: >
      {"device":"light","address":"AC/0x0002A95/1","data":"Off"}
    payload_on: >
      {"device":"light","address":"AC/0x0002A95/1","data":"On"}
    state_off: "Off"
    state_on: "On"
    state_topic: dhjm/rfxgateway/AC/0x0002A95/1
    unique_id: rf-4676eecb-fe7f-4919-a04f-f56be91ad1ee
    optimistic: true
    payload_off: >
      {"device":"light","address":"AC/0x00030CE/4","data":"Off"}
    payload_on: >
      {"device":"light","address":"AC/0x00030CE/4","data":"On"}
    state_off: "Off"
    state_on: "On"
    state_topic: dhjm/rfxgateway/AC/0x00030CE/4
    unique_id: rf-ec4e648a-2927-4e2a-9d78-c7efc41f8cd2
    optimistic: true
    payload_off: >
      {"device":"light","address":"AC/0x00006224/2","data":"Off"}
    payload_on: >
      {"device":"light","address":"AC/0x00006224/2","data":"On"}
    state_off: "Off"
    state_on: "On"
    state_topic: dhjm/rfxgateway/AC/0x00006224/2
    unique_id: rf-b8f166d7-c6ed-44fe-8a37-646ba11305ab
(Use https://www.uuidgenerator.net/ to generate your unique IDs - so that you can customise your entities in the UI)
In the same file. You can have some switches in the new format and some in the old format just fine. Just can’t shove them into exactly the same file.
Assuming your configuration.yaml now includes this:
mqtt: !include mqtt.yaml
Then yes, that’s fine.
