HI,
might be terribly stupid question, but here goes:
my known_devices.yaml is getting rather long, so i tried to split it up in a subfolder and following configuration:
in configuration.yaml:
known_devices: !include_dir_merge_named known_devices
which leads to the following error in the log…:
2017-12-15 11:23:01 ERROR (MainThread) [homeassistant.loader] Unable to find component known_devices
2017-12-15 11:23:01 ERROR (MainThread) [homeassistant.setup] Setup failed for known_devices: Component not found.
Isn’t this possible? if it is, what am i doing wrong? i do still have a (empty) known_devices.yaml in that directory, for the system to write newly tracked devices to.
btw: all components are shown correctly, and seem to behave just fine in the frontend…
btw2:
if i state it under homeassistant: at the top of the file i get the following error:
2017-12-15 11:35:23 ERROR (MainThread) [homeassistant.config] Invalid config for [homeassistant]: [known_devices] is an invalid option for [homeassistant]. Check: homeassistant->known_devices. (See /config/configuration.yaml, line 5).
Failed config
Thanks,
Marius
