Spliting configuration
I do want to split the configuration:
I read a lot of error-threads, but can not filter out, why mine is not working.
1st try:
homeassistant:
  packages: !include_dir_merge_named packages
Error message for try one:
expected a dictionary for dictionary value @ data['packages']['shell_command']
2nd try:
homeassistant:
  packages:
    mailcowaliases: !include packages/packages_dir/package_file.yaml
3nd try: 8with and without trailing /)
homeassistant:
  packages:
    mailcowaliases: !include_dir_merge_list packages/
But none of them worked the way I expected.
At first, I have to full restart HA from developer tools to update changes.
The only version I got to work for the half was version two, but I do not want to give all the names of all yaml-files to the config.
here are three versions of the yaml, all have some other error messages as long as I change some of the above lines in configuration.yaml.
At the moment I got no message on restart, I got a message for the shell_command after pressing the button. But this is part of an other thread.
- input_text:
    txt_1:
      initial: "1"
    txt_2:
      initial: "2"
- input_button:
    btn_1:
    btn_2:
- shell_command:
    shellcommand_add_la: >
      curl "https://subd.dom.tld" \
      -X POST \
      --header "Content-Type: application/json" \
      --header "X-K: xxx" \
      --header "Authorization: Basic xxx" \
      -d "{\"ad\" : \"{{ states('input_text.txt_la') }}\", \"active\": 1,\"comment\": \"\"}"
      -X POST \
an other version:
input_text:
  txt_1:
    initial: "1"
  txt_2:
    initial: "2"
input_button:
  btn_1:
  btn_2:
shell_command:
    -X POST \
    -X POST \
an other version
- input_text:
    - txt_1:
        initial: "1"
    - txt_2:
        initial: "2"
- input_button:
    - btn_1:
    - btn_2:
- shell_command:
    - shellcommand_add_la: >
        -X POST \
        -X POST \
I’m using packages (my directory is named the same):
homeassistant:
#### PACKAGES
  packages: !include_dir_named packages
My packages directory (example weather package):
/config
— packages
—— weather
——— automations_weather
———— freeze_warning.yaml
———— storm_warning.yaml
——— sensors_weather.yaml
Example /config/packages/weather/automations_weather/freeze_warning.yaml:
automation:
- id: blabla1
      alias: bla1
      trigger: …
- id: blabla2
      alias: bla2
      trigger: …
See: Splitting Configuration using packages - #5 by AhmadK and Packages - Home Assistant
Do you have shell_commands (Multiline?), input_text or input_button declared, too?
I see something, that I can not unterstand, too.
I used
or
You use:
include_dir_named
I tried with your version and have:
- input_text:
    - txt_1:
      initial: "1"
    - txt_2:
      initial: "2"
I think like you wrote, but I get this error:
Package package_file setup failed. Component input_text cannot be merged. Expected a dict.
Compare it with my example.
File example.yaml:
input_boolean:
  boolean_one:
    icon: mdi:cat
  boolean_two:
    icon: mdi:dog
input_text:
    text_one:
    text_two:
my fault (copy and paste).
I have this.
input_text:
- txt_1:
initial: “1”
- txt_2:
initial: “2”
I removed everything else out of the file and tried to check the config via developer tools and got:
</s> <s>Package package_file setup failed. Component input_text cannot be merged. Expected a dict.</s> <s>
I use:
I use now:
input_text:
  txt_1:
    initial: "1"
  txt_2:
    initial: "2"
And I got no errors by testing, no I move on to test the resst.
Which button do I have to press to reload the full package instead restart HA all the time and wait 3 minuntes.
Go to Developer Tools —> YAML. There you can see the integrations that can be reloaded without restarting HA.
Yes, but I do not want to try them all out if I made some changes to differents entitiy-types in one package.
If, for instance, a package contains an automation, an input_number and a script, and you edit all three, you have to reload those three. Or am I misunderstanding you?
No, but I want to reload the whole package-yaml, instead of clicking on all things one by one.
Maybe I forgot that I changed parts of the sensor and only reload the automation part.
In this case, at least I know of no other possibility than to restart HA.
lazy man, me, remembered about autohotkey … some research and developing later … I have a Hotkey which does this job for me, I have only wait some seconds :smiley:
You wish will be fulfilled in the upcoming core release: Quick Reload
