I am trying to place some of my code in another yaml file and use the !include command, but, for whatever reason, even after all the guides and youtube videos I watched (even DrZz’s and frenck video), I still get an error each time…
I want to take this part and place it in another yaml file
What do your sensibo sensors look like? I don’t believe you can just create a new type and include it, if they’re created as sensor.[name] they would be pulled in as sensor: !include sensor.yaml, or climate.[name] then climate: include climate.yaml.
If you look at the doc’s that may help:
!include filename.yaml is the statement that tells Home Assistant to insert the contents of filename.yaml at that point. This is how we are going to break a monolithic and hard to read file (when it gets big) into more manageable chunks.
As per @ardysusilo if you’re using template then in configuration.yaml you’ll have:
template: !include [filename].yaml (would be sensible to name it template.yaml!)
Then within template.yaml
- sensor:
- name: blurb
state: blurb
- name: blurb
state: blurb ....etc as per ardysusilo
The include is simply inserting the named file back into the main configuration.yaml at that point (e.g. template: then the file contents)
You may be looking for packages which does allow you to bundle different stuff together, but I’d advise getting your head around includes before attempting packages:
I only discovered this ‘packages’ recently and it fixes almost all of my challenges where I have quite a few “integrations” that are split over multiple sensors. Managing them in files by their type (binary/sensor/command_line) is making it a mess wrt to overview, a recent change supportig that is the move of command_line to the configuration.yaml (or a command_line yaml)
Is there anything against using yaml with combined types?
EDIT:
I have flight related info, requiring command_line, rest, sensor and binary sensor
I have energy related, which reuqires template, sensor, utility meter
If you’re talking about packages then no. You can combine these (including the command_line you mentioned). You just need the namespace in the package yaml file. One of my package files looks like this (truncated) and has template binary sensors, sensors and command line sensors in it:
# Required to support the Home Assistant dashboard page and reporting/automation
template:
- binary_sensor:
- name: Monitor Home Assistant
device_class: problem
state: ...
- name: Monitor Updates
device_class: update
state: ...
- platform: systemmonitor
scan_interval: 120
resources:
- type: processor_use
- type: memory_use_percent
command_line:
- sensor:
name: Processor Temperature
command: …
Hey all,
after all these mixed answers I want to add my opinion. Everyone should work with packages from the outset.
The concept provides higher flexibility and invites users to organize things in a way that makes sense. Most of the issues users have with a combined configuration.yaml are immediately solved by it. The approach shown by @myle is an anti-pattern and will not help to better structure and maintain a complex configuration (no offense!).
