Henrik1986
(Henrik1986)
September 11, 2016, 7:44pm
1
Hi! Trying to split my configuration file and get stuck on customize:
In my configuration.yaml I wrote:
customize: !include customizing.yaml
My customizing.yaml includes this.
- sensor.yr_humidity:
friendly_name: Luftfuktighet
icon: mdi:water-percent
- sensor.yr_temperature:
friendly_name: Tempertur
icon: mdi:temperature-celsius
- sensor.yr_wind_speed:
friendly_name: Vindhastighet
icon: mdi:weather-windy
- sensor.yr_condition:
friendly_name: Nederbörd
icon: mdi:weather-rainy
- sensor.yr_precipitation:
- sensor.yr_symbol:
friendly_name: Väderlek
- sun.sun:
friendly_name: Sol
hidden: true
- device_tracker.linuxlan:
icon: mdi:raspberrypi
- device_tracker.philipslan:
icon: mdi:lightbulb
- device_tracker.routerlan:
icon: mdi:router-wireless
- device_tracker.tivoe800d5bf0c82f56lan:
icon: mdi:monitor
- device_tracker.android8f3ebbf27d050e6flan:
icon: mdi:tablet-android
- device_tracker.arbetsrumlan:
icon: mdi:laptop
- device_tracker.madeleinesmbplan:
icon: mdi:laptop-mac
- device_tracker.mediaserverlan:
icon: mdi:server
In my loggfile i found this
homeassistant.bootstrap: Invalid config for [homeassistant]: Expected dictionary for dictionary value @ data[‘customize’]. Got [OrderedDict([(‘sensor.yr_humidity’, OrderedDict([(‘friendly_name’, ‘Luftfuktighet’), (‘icon’, ‘mdi:water-percent’)]))]), OrderedDict([(‘sensor.yr_temperature’, OrderedDict([(‘friendly_name’, ‘Tempertur’), (‘icon’, ‘mdi:temperature-celsius’)]))]), OrderedDict([(‘sensor.yr_wind_speed’, OrderedDict([(‘friendly_name’, ‘Vindhastighet’), (‘icon’, ‘mdi:weather-windy’)]))]), OrderedDict([(‘sensor.yr_condition’, OrderedDict([(‘friendly_name’, ‘Nederbörd’), (‘icon’, ‘mdi:weather-rainy’)]))]), OrderedD… (See /var/opt/homeassistant/configuration.yaml:3)
jbardi
(casperboo)
September 11, 2016, 7:49pm
2
When pasting code in the forum, you need to use the Preformatted Text option on the toolbar of the editor, it looks like this icon:
Otherwise we can not tell the spacing and formatting you used in your configuration.yaml
Hilight the code and click that button so we can see your code how it really is
rpitera
(Robert Pitera)
September 11, 2016, 7:58pm
3
Other than the dashes, it looks correct.
Henrik1986
(Henrik1986)
September 11, 2016, 8:00pm
5
Under sensors and devices? I
icon, fiendley_name?
PtP
(Mike)
September 11, 2016, 8:01pm
6
Change the file name to customize.yaml and make sure customize: ! include customize.yaml is directly under time_zone: and not with your other ! includes.
rpitera
(Robert Pitera)
September 11, 2016, 8:06pm
7
Here’s the first section of my customize.yaml (not going to post the whole thing because it’s long):
# Customizations #
# Sensors
# Forecast.io
sensor.forecastio_cloud_coverage:
friendly_name: Cloud Coverage
icon: mdi:cloud-outline
sensor.forecastio_humidity:
friendly_name: Outdoor Humidity
icon: mdi:water
sensor.forecastio_pressure:
friendly_name: Barometric Pressure
icon: mdi:nature
sensor.forecastio_temperature:
icon: mdi:thermometer
friendly_name: Outdoor Temp
sensor.forecastio_wind_speed:
friendly_name: Wind Speed
sensor.forecastio_summary:
friendly_name: Condition
sensor.forecastio_ozone:
friendly_name: Ozone Levels
sensor.forecastio_precip_probability:
friendly_name: Prob of Precip
sensor.forecastio_precip:
friendly_name: Precip Type
sensor.forecastio_precip_intensity:
friendly_name: Precip Intensity
icon: mdi:weather-pouring
sensor.forecastio_visibility:
friendly_name: Visibility
icon: mdi:weather-fog
sensor.forecastio_nearest_storm_distance:
friendly_name: Nearest Storm
icon: mdi:weather-lightning
sensor.forecastio_wind_bearing:
friendly_name: Wind Bearing
icon: mdi:apple-safari
sensor.forecastio_apparent_temperature:
friendly_name: Real Feel
icon: mdi:account-alert
sensor.forecastio_dew_point:
friendly_name: Dew Point
icon: mdi:oil-temperature
rpitera
(Robert Pitera)
September 11, 2016, 8:07pm
8
This is the big one that everybody misses first time around.
Edit: Myself included.
RonJ103
(Jeremy Scuteri)
November 11, 2017, 10:12pm
11
Is it required to have a single space for the 1st level of indent?
kopfsick
(Julian Hanssen)
December 27, 2017, 8:42am
12
This worked for me. But I don’t get the logic as to why I should have a single leading space on each line i customize.yaml. In my head there should be either zero spaces or two spaces.
Can anyone explain?
