I’m struggling trying to split my mqtt.yaml file by device.
I have a bunch of mqtt devices with lots of sensors, switches, etc…
For the ease of use and editing I would like to have one file per device under mqtt/ directory having ALL device entities.
I then specified the following in configuration.yaml
mqtt: !include_dir_merge_named mqtt/
One of the mqtt file (esp_altherma.yaml)
#mqtt:
binary_sensor:
- unique_id: HP_Defrost
name: "HP defrost mode"
state_topic: 'esp_altherma/ATTR'
value_template: "{{ value_json['Defrost Operation'] }}"
availability_topic: "esp_altherma/LWT"
payload_available: "Online"
payload_not_available: "Offline"
payload_on: "ON"
payload_off: "OFF"
- unique_id: HP_Oil_Return
name: "HP oil return mode"
value_template: "{{ value_json['Oil Return Operation'] }}"
payload_on: "ON"
payload_off: "OFF"
- unique_id: HP_Target_Temp
name: 'HP Water Target T°'
unit_of_measurement: '°C'
value_template: "{{ value_json['Target Cond. Temp.']|round(2)}}"
- unique_id: HP_Outdoor_Air_Temp
value_template: "{{ value_json['Outdoor air temp.'] }}"
- unique_id: HP_Outdoor_Heat_Exchanger_Temp
name: 'HP Outdoor Heat Exchanger'
value_template: "{{ value_json['Outdoor heat exchanger temp.'] }}"
switch:
- unique_id: HP_switch
state_topic: "esp_altherma/STATE"
command_topic: "esp_altherma/cmd"
payload_on: "on"
payload_off: "off"
state_on: "ON"
state_off: "OFF"
optimistic: false
qos: 0
retain: false
I saw some topics where it is detailed a split configuration where the split criteria is based on entities like sensors, switches, etc… but it is not my will…
