Hi everyone, I would like to separate and keep my configuration file tidy but I’m having problems with the !include command.
I would like to separate the files of the different sensors into multiple files.
Furthermore I have to create binary sensors and when I go to divide them into different files they cause me errors.
I attach the configuration files, if anyone can help me, thank you very much!
this is the configuration.yaml
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
modbus:
type: tcp
host: 192.168.1.90
port: 4196
sensors:
#CONTECA 42
- name: MSB_heating_energy42
unique_id: MSB_heating_energy42
slave: 42
address: 2
precision: 2
unit_of_measurement: kWh
- name: LSB_heating_energy42
unique_id: LSB_heating_energy42
slave: 42
address: 3
precision: 2
- name: MSB_cooling_energy42
unique_id: MSB_cooling_energy42
slave: 42
address: 4
precision: 2
- name: LSB_cooling_energy42
unique_id: LSB_cooling_energy42
slave: 42
address: 5
- name: Instantaneous_power42
unique_id: Instantaneous_power42
slave: 42
address: 14
precision: 2
- name: Instantaneous_flow42
unique_id: Instantaneous_flow42
slave: 42
address: 15
precision: 2
unit_of_measurement: m3/h
- name: Flow_temp42
unique_id: Flow_temp42
slave: 42
address: 16
precision: 2
scale: 0.1
unit_of_measurement: °C
device_class: temperature
- name: Return_temp42
unique_id: Return_temp42
slave: 42
address: 17
precision: 2
scale: 0.1
- name: Difference_temp42
unique_id: Difference_temp42
slave: 42
address: 18
precision: 2
scale: 0.1
- name: MSB_heating_mass_counter42
unique_id: MSB_heating_mass_counter42
slave: 42
address: 27
- name: LSB_heating_mass_counter42
unique_id: LSB_heating_mass_counter42
slave: 42
address: 28
precision: 2
- name: MSB_cooling_mass_counter42
unique_id: MSB_cooling_mass_counter42
slave: 42
address: 29
precision: 2
- name: LSB_cooling_mass_counter42
unique_id: LSB_cooling_mass_counter42
slave: 42
address: 30
precision: 2
- name: Maximum_instantaneous_power42
unique_id: Maximum_instantaneous_power42
slave: 42
address: 31
precision: 2
- name: Maximum_instantaneous_flow42
unique_id: Maximum_instantaneous_flow42
slave: 42
address: 32
precision: 2
- name: Pulse_counterMSB42
unique_id: Pulse_counterMSB42
slave: 42
address: 6
precision: 2
- name: Pulse_counterLSB42
unique_id: Pulse_counterLSB42
slave: 42
address: 7
precision: 2
- name: Pulse_counter_MSBextra42
unique_id: Pulse_counter_MSBextra42
slave: 42
address: 10
precision: 2
- name: Pulse_counter_LSBextra42
unique_id: Pulse_counter_LSBextra42
slave: 42
address: 11
precision: 2
#CONTECA 41
- name: MSB_heating_energy41
unique_id: MSB_heating_energy41
slave: 41
address: 2
precision: 2
- name: LSB_heating_energy41
unique_id: LSB_heating_energy41
slave: 41
address: 3
precision: 2
- name: MSB_cooling_energy41
unique_id: MSB_cooling_energy41
slave: 41
address: 4
precision: 2
- name: LSB_cooling_energy41
unique_id: LSB_cooling_energy41
slave: 41
address: 5
- name: Instantaneous_power41
unique_id: Instantaneous_power41
slave: 41
address: 14
precision: 2
- name: Instantaneous_flow41
unique_id: Instantaneous_flow41
slave: 41
address: 15
precision: 2
- name: Flow_temp41
unique_id: Flow_temp41
slave: 41
address: 16
precision: 2
scale: 0.1
- name: Return_temp41
unique_id: Return_temp41
slave: 41
address: 17
precision: 2
scale: 0.1
- name: Difference_temp41
unique_id: Difference_temp41
slave: 41
address: 18
precision: 2
scale: 0.1
- name: MSB_heating_mass_counter41
unique_id: MSB_heating_mass_counter41
slave: 41
address: 27
- name: LSB_heating_mass_counter41
unique_id: LSB_heating_mass_counter41
slave: 41
address: 28
precision: 2
- name: MSB_cooling_mass_counter41
unique_id: MSB_cooling_mass_counter41
slave: 41
address: 29
precision: 2
- name: LSB_cooling_mass_counter41
unique_id: LSB_cooling_mass_counter41
slave: 41
address: 30
precision: 2
- name: Maximum_instantaneous_power41
unique_id: Maximum_instantaneous_power41
slave: 41
address: 31
precision: 2
- name: Maximum_instantaneous_flow41
unique_id: Maximum_instantaneous_flow41
slave: 41
address: 32
precision: 2
- name: Pulse_counter_MSBextra41
unique_id: Pulse_counter_MSBextra41
slave: 41
address: 10
precision: 2
- name: Pulse_counter_LSBextra41
unique_id: Pulse_counter_LSBextra41
slave: 41
address: 11
precision: 2
- name: Pulse_counterMSB41
unique_id: Pulse_counterMSB41
slave: 41
address: 6
precision: 2
- name: Pulse_counterLSB41
unique_id: Pulse_counterLSB41
slave: 41
address: 7
precision: 2
slave: 41
address: 7
precision: 2
#SENECA
- name: Seneca_sonda_temp1
unique_id: Seneca_sonda_temp1
slave: 43
address: 6
data_type: float32
precision: 2
- name: Seneca_sonda_temp2
unique_id: Seneca_sonda_temp2
slave: 43
address: 8
data_type: float32
precision: 2
#LEGIOMIX
- name: Legiomix_model
unique_id: Legiomix_model
slave: 40
address: 0
- name: Legiomix_ID_modbus
unique_id: Legiomix_ID_modbus
slave: 40
address: 1
- name: Legiomix_T1
unique_id: Legiomix_T1
slave: 40
address: 2
scale: 0.01
precision: 2
- name: Legiomix_T2
unique_id: Legiomix_T2
slave: 40
address: 3
precision: 2
scale: 0.01
- name: Legiomix_status
unique_id: Legiomix_status
slave: 40
address: 6
- name: Legiomix_adjustment_status
unique_id: Legiomix_adjustment_status
slave: 40
address: 9
- name: Legiomix_motor_status
unique_id: Legiomix_motor_status
slave: 40
address: 10
- name: Legiomix_configuration
unique_id: Legiomix_configuration
slave: 40
address: 1005
- name: Legiomix_disinfection_start_day
unique_id: Legiomix_disinfection_start_day
slave: 40
address: 1011
- name: Legiomix_setpoint_temperature
unique_id: Legiomix_setpoint_temperature
slave: 40
address: 1006
precision: 2
scale: 0.01
slave: 40
address: 2001
- name: Legiomix_motor_test
unique_id: Legiomix_motor_test
slave: 40
address: 2004
- name: Legiomix_alarms
unique_id: Legiomix_alarms
slave: 40
address: 7
binary_sensor: !include_dir_list 485/
this is one of the binary file:
sensors:
alarm_bit_1:
friendly_name: "ALARM Bit 1"
value_template: >
{% if states('sensor.Legiomix_alarms')|int|bitwise_and(1) > 0 %}
ATTIVO
{% else %}
non attivo
{% endif %}
alarm_bit_3:
friendly_name: "ALARM Bit 3"
value_template: >
{% if states('sensor.Legiomix_alarms')|int|bitwise_and(4) > 0 %}
ATTIVO
{% else %}
non attivo
{% endif %}
alarm_bit_4:
friendly_name: "ALARM Bit 4"
value_template: >
{% if states('sensor.Legiomix_alarms')|int|bitwise_and(8) > 0 %}
ATTIVO
{% else %}
non attivo
{% endif %}
alarm_bit_5:
friendly_name: "ALARM Bit 5"
value_template: >
{% if states('sensor.Legiomix_alarms')|int|bitwise_and(16) > 0 %}
ATTIVO
{% else %}
non attivo
{% endif %}
alarm_bit_6:
friendly_name: "ALARM Bit 6"
value_template: >
{% if states('sensor.Legiomix_alarms')|int|bitwise_and(32) > 0 %}
ATTIVO
{% else %}
non attivo
{% endif %}
alarm_bit_7:
friendly_name: "ALARM Bit 7"
value_template: >
{% if states('sensor.Legiomix_alarms')|int|bitwise_and(64) > 0 %}
ATTIVO
{% else %}
non attivo
{% endif %}
alarm_bit_8:
friendly_name: "ALARM Bit 8"
value_template: >
{% if states('sensor.Legiomix_alarms')|int|bitwise_and(128) > 0 %}
ATTIVO
{% else %}
non attivo
{% endif %}
alarm_bit_9:
friendly_name: "ALARM Bit 9"
value_template: >
ATTIVO
{% else %}
non attivo
{% endif %}
alarm_bit_10:
friendly_name: "ALARM Bit 10"
value_template: >
ATTIVO
{% else %}
non attivo
{% endif %}e
