Splitting yaml
I am trying to split up my configuration.yaml file into several but keep getting an error when trying.
I have created a customize.yaml with success but when trying with light, Groups, sensors and so on it returns an error.
Configuration yaml looks like this:
elevation: 20
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Copenhagen
customize: !include customize.yaml
group: !include groups.yaml
Groups yaml looks like this:
Groups yaml (hashtag is in front of the original text)
stue:
view: true
entities:
- light.pendel_op
- light.bordlampe_ned
- light.bordlampe_op
- light.pendel_ned
- light.pendel_ned_2
- light.pendel_ned_3
- light.pendel_op
- light.strip_stue
- light.strip_trappe
- light.stue
- media_player.stue
sovevaerelse:
view: true
entities:
- light.sovevrelse_loft
- light.sovevrelse_skab
Error from log file:
17-04-15 09:50:41 ERROR (MainThread) [homeassistant.config] Invalid config for [homeassistant]: [group] is an invalid option for [homeassistant]. Check: homeassistant->group. (See /home/homeassistant/.homeassistant/configuration.yaml, line 2).
Failed config
homeassistant:
customize: [source /home/homeassistant/.homeassistant/configuration.yaml:12]
light.bordlampe_ned: [source /home/homeassistant/.homeassistant/customize.yaml:3]
icon: mdi:lamp
light.bordlampe_op: [source /home/homeassistant/.homeassistant/customize.yaml:5]
icon: mdi:lamp
and so on
Can someone see what is wrong?
You have group: indented under your home assistant header - you need to change it from this:
homeassistant:
  elevation: 20
to this:
homeassistant:
  elevation: 20
So that group is a category of it’s own.
Hope this helps.
How come it should not be intended like the customize line?
So lights, sensors and other yaml files also has to be a category of their own in the configuration.yaml?
Because groups, lights, sensors etc are separate components, whereas customize is an option of the homeassistant component.
[edit] - slightly misread your last post the first time.
Yes, is the answer to your question, the basic format for the yaml entries is:
component:
  option1:
    option1's_suboptions:
  option2:
  ETC
So in your case:
homeassistant:
  elevation:
  unit_system:
  customize:
group:
light:
okay thanks :-)… i will try it out later in the afternoon.
Works perfectly now :slight_smile:
