Hi everyone, I’ve just flashed the SD card with hass.io image. I’ve tried tu run connected trough HDMI and Ethernet but it is blocked repeating always the same two lines
IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
brcmfmac: power management disabled
What can I do?
I can reach the “preparing hass.io” page though il but not through the hassio.local
I’ve alrrady waited for hours but nothing happens.
If you’re not using IPv6, I wouldn’t worry about it.
You say you can reach the web interface through IP-address, but not by using ‘hassio.local’. This looks a lot like a DNS problem. Your internal device (router, NAS, server, or something similar) running DNS does not have the hassio.local registered to the IP address.
When you connect to the web interface using IP, do you get a login screen? I you do, HAssio should work fine.
I can reach the hassio.local with iPhone but with the MacBook I need to use the ip address. In both the cases I reach the page saying that in 20 minutes everything should be ready but after hours nothing happens and The only message on the hdmi monitor is the same Two rows repeated.
About IPv6, is disabled in the router page, i do not use this.
