Sorry that there is such a stress in the other topic teamtracker.
No problem. I thought about it today. Just create a group that has all your favorites in it Then iterate over that groups entities. So I will add this in the documentation, simple post here:
Just create a group using the group helper or using YAML if you prefer. FOr example in YAML:
group:
team_favorities:
name: Team Favorities
entities:
- sensor.detroit_lions
- sensor.detroit_pistons
- sensor.detroit_red_wings
- sensor.detroit_tigers
Then an example using auto-entities could be this.
type: custom:auto-entities
unique: true
show_empty: false
card:
type: custom:layout-card
layout_type: masonry
card_param: cards
filter:
template: |
{%- for team in state_attr('group.team_favorities','entity_id') -%}
{%- if state_attr(team, "team_homeaway") == "home" -%}
{{{"type": "custom:teamtracker-card",
"entity": team,
"home_side": "right"}}},
{%- endif -%}
{%- endfor -%}
exclude:
- entity_id: '*team_tracker*'
sort:
method: attribute
attribute: date
Because this has the IF that filters out only the home teams, if two favorites are playing eachother, only the home team is listed. Tested right now by adding the Avalanche in the group and it lists Wings v Avalanche only once even though both are favorites.
Ok, I have create a helper with the typ group (sensor.nhl_favoriten)
but this code don`t work:
unique: true
show_empty: false
card:
card_param: cards
filter:
template: |
{%- for team in state_attr('sensor.nhl_favoriten','entity_id') -%}
"entity": team,
{%- endif -%}
{%- endfor -%}
exclude:
sort:
method: attribute
attribute: date
If I go to develloper tools I see this:
What make I wrong?
I donāt use helpers because I cannot see. Can you grab screenshot of helper? It looks like there are no entities. Mine is like this:
YOu would create a Group in Help choosing āSensor groupā.
Then add members which would be the teams you wish like āsensor.seattle_krakenā.
I think I see the issue, it is totally unclear what to āchooseā for the last field to me ā Please use YAML to configure
ok, I have now use yaml and create the group. Now it works.
But how can I add the markdown code:
- type: markdown
content: >-
<table> <tr> <td> Red Wings (Seider)
<img src =
'https://a.espncdn.com/i/teamlogos/nhl/500/scoreboard/det.png'
height='80'></img> </td> <td> Senators
(StĆ¼tzle) <img src =
'https://a.espncdn.com/i/teamlogos/nhl/500/scoreboard/ott.png'
height='80'></img> </td> </tr> <tr> <td> Oilers
(Draiseitl) <img src =
'https://a.espncdn.com/i/teamlogos/nhl/500/scoreboard/edm.png'
height='80'></img> </td> <td> Kraken (Grubauer)
<img src =
'https://a.espncdn.com/i/teamlogos/nhl/500/scoreboard/sea.png'
height='80'></img> </td> </tr> </table>
- type: markdown
content: |-
Link um Athleten/Teamname herauszufinden:
NHL: https://www.espn.co.uk/nhl/teams
after this code:
- attributes:
label: Favoriten
icon: mdi:star
card:
unique: true
show_empty: false
card:
card_param: cards
filter:
template: |
{%- for team in state_attr('group.nhl_favorities','entity_id') -%}
"entity": team,
{%- endif -%}
{%- endfor -%}
exclude:
sort:
method: attribute
attribute: date
I need a picture of what you are trying to display. THe auto-entities will create a card for each entity in the list of entities in your group. WHat else are you trying to display and where?
A whole new set of cards. If you look at that code it is displaying a card for each home team in your array of favorites. The core is here:
"entity": team,
Create another card that uses type: markdown
in the same way.
Now, that said ā¦ are you looking more for a āplayerā tracker?
I was contemplating this and I think I could do way more.
As a matter of fact, I was thinking of doing a fantasy view.
Is that what you are looking for?
I think Iām just indenting it wrong. this is my code.
- attributes:
label: Favoriten
icon: mdi:star
card:
unique: true
show_empty: false
card:
card_param: cards
filter:
template: >
{%- for team in
"entity": team,
{%- endif -%}
{%- endfor -%}
exclude:
sort:
method: attribute
attribute: date
type: markdown
content: >+
<table> <tr> <td>
Red Wings (Seider)
<img src ='https://a.espncdn.com/i/teamlogos/nhl/500/scoreboard/det.png' height='80'></img> </td>
<td> Senators
(StĆ¼tzle) <img src ='https://a.espncdn.com/i/teamlogos/nhl/500/scoreboard/ott.png' height='80'></img> </td> </tr>
<tr> <td>
Oilers (Draiseitl) <img src ='https://a.espncdn.com/i/teamlogos/nhl/500/scoreboard/edm.png' height='80'></img> </td>
<img src ='https://a.espncdn.com/i/teamlogos/nhl/500/scoreboard/sea.png' height='80'></img> </td> </tr> </table>
But the markdown don`t display
Yes:
type: vertical-stack
cards:
- type: custom:auto-entities
unique: true
show_empty: false
card:
card_param: cards
filter:
template: |
"entity": team,
{%- endif -%}
{%- endfor -%}
exclude:
sort:
method: attribute
attribute: date
- type: markdown
content: >+
<table> <tr> <td>
Red Wings (Seider)
<td> Senators
<tr> <td>
You need a container to put the cards in. In my case I put them into a vertical-stack
Ok but my problem ist, to put this in you dashboard code.
This is my new code:
type: custom:mod-card
card_mod:
style:
tabbed-card $: |
mwc-tab {
background: var(--ha-card-background, var(--card-background-color, white) );
border-color: var(--ha-card-border-color, var(--divider-color, #e0e0e0) );
border-width: 2px;
border-top-left-radius: 20px;
border-top-right-radius: 20px;
border-style: solid;
overflow: hidden;
width: 25%;
mwc-tab[active] {
background: #EBFFD8 !important;
card:
type: custom:tabbed-card
styles:
'--mdc-theme-primary': green
'--mdc-tab-text-label-color-default': silver
'--mdc-typography-button-font-size': 12px
tabs:
- attributes:
label: NHL
icon: mdi:hockey-puck
card:
card_mod:
style:
tabbed-card $: |
mwc-tab {
border-width: 2px;
overflow: hidden;
width: 25%;
mwc-tab[active] {
card:
styles:
tabs:
- attributes:
label: Games
icon: mdi:hockey-sticks
card:
card_mod:
style:
tabbed-card $: |
mwc-tab {
border-width: 2px;
overflow: hidden;
width: 25%;
mwc-tab[active] {
card:
styles:
tabs:
- attributes:
label: Favoriten
icon: mdi:star
cards:
unique: true
show_empty: false
card:
card_param: cards
filter:
template: |
"entity": team,
{%- endif -%}
{%- endfor -%}
exclude:
sort:
method: attribute
attribute: date
- type: markdown
content: >+
<table> <tr> <td>
Red Wings (Seider)
<td> Senators
<tr> <td>
- attributes:
label: POSTGAME
card:
type: custom:decluttering-card
template: game_stats
variables:
- sport: NHL
- status: POST
- attributes:
label: Live
card:
variables:
- sport: NHL
- status: IN
- attributes:
label: PREGAME
icon: mdi:map-clock-outline
card:
variables:
- sport: NHL
- status: PRE
- attributes:
label: Standings
icon: mdi:ballot
card:
card_mod:
style:
tabbed-card $: |
mwc-tab {
border-width: 2px;
overflow: hidden;
width: 25%;
mwc-tab[active] {
card:
styles:
tabs:
- attributes:
label: Divisional
card:
type: custom:stack-in-card
mode: vertical
cards:
- type: custom:decluttering-card
template: nhl_settings
variables:
- title: Eastern Atlantic
- entity: sensor.nhl_east_atlantic
- sort: >-
x.stats.find(y=>y.shortDisplayName ==
'PTS').value
variables:
- title: Eastern Metropolitan
- entity: sensor.nhl_east_metropolitan
- sort: >-
'PTS').value
variables:
- title: West Central
- entity: sensor.nhl_west_central
- sort: >-
'PTS').value
variables:
- title: West Pacific
- entity: sensor.nhl_west_pacific
- sort: >-
'PTS').value
- attributes:
label: Conference
card:
mode: vertical
cards:
variables:
- title: Eastern
- entity: sensor.nhl_east_*
- sort: >-
'PTS').value
variables:
- title: Western
- entity: sensor.nhl_west_*
- sort: >-
'PTS').value
- attributes:
label: Overall
card:
variables:
- title: Overall
- entity: sensor.nhl_*_*
- sort: x.stats.find(y=>y.shortDisplayName == 'PTS').value
- attributes:
label: Playoffs
card:
mode: vertical
cards:
variables:
- title: Eastern
- sort: x.stats[5].value * -1
variables:
- title: Western
But with this code display only this:
Although I havenāt made any more changes to the code, a few boxes now appear. But my text from markdown is still missing.
I have this in my group.yaml
team_favorities:
name: NHL Favoriten
entities:
- sensor.ottawa_senators
- sensor.edmonton_oilers
- sensor.seattle_kraken
- sensor.san_jose_sharks
- sensor.new_york_rangers
- sensor.los_vegas_golden_knights
But now I don`t see:
Why are the two teams and the markdown are missing?
Team favorites sensor was likely created with no āentity_idā.
This means when you changed it, it likely got a new name ā¦ like in your case:
sensor.nhl_favoriten_2
Check and see if this happened.
Also one note, I see āsensor.los_vegas_golden_knightsā you may have named it that way but in reality it is āLas Vegasā not āLos Vegasā. Although you can name it whatever you like.
Also another note ā¦ if you have the home/away setting in place and they are only an away team, they may not appear. It depends on where you apply the home/away filter. I added my favorites at a higher level because I wanted to show all the sports. I canāt do home/away for example for the NCAAM basketball because I do not believe they have home/away status as they play at a neutral site.
In looking at yours, you are applying the home/away filter with the if inside. I would bet that the missing games are because they were away games? Please check. That would make sense I think, if a favorite is playing a non-favorite and the game is an away game for the favorite, they would likely not appear.
I only tested:
Fav (home) v. Non-Fav (away)
Fav (home) v Fav (away)
I did not test:
Non-Fav (home) v. Fav (away)
It is probably this one that is missing.
This would be a semi-complicated template to think through.
- Fav team @ home ā show it
- Fav team @ away, check if the opponent is also a Fav team
ā If yes, donāt show it because it will be shown in because of rule #1 above
ā If no, show it
It is possible that setting auto-entities to provide only unique entries might do it
No the sensor is group.team_favorities:
The Name from the Golden Knights are in your senaor.yaml on github:
- platform: teamtracker
league_id: NHL
team_id: VGK
name: Los Vegas Golden Knights
Yes you are right, the missing are away teams. I donĀ“t see that because Iām only now noticing that the game pairings are displayed the other way around, the away team is always at the front.
All displaye are Home Teams:
And Game Sharks and Oilers are both favorietes.
But Why my markdown card are not displayed?
I have no idea about the markdown card, likely bad indenting. If you implement like this (removing home/away if and adding just unique: true) this may work:
- attributes:
label: FAVORITES
icon: mdi:heart
card:
mode: horizontal
columns: 4
cards:
unique: true
show_empty: false
card:
card_param: cards
filter:
template: >
{%- for team in
"entity": team,
{%- endfor -%}
exclude:
unique: true
sort:
method: attribute
attribute: date
Of course, change to your group sensor name. I am not clear this will work though as I do not have many favorites in one sport, I have one per sport. So mine never play eachother (unless the Red Wings decide to become a baseball team!)
UPDATE: I added the Kraken and Senators to my favorites and now I see this:
So it looks to me as the unique works. The real question now is if I add the Penguins or the Stars do I get two entries. If so, then this will still not work.
UPDATE: Yes this will not work either, the only way is like I wrote above in a complicated template:
With the modified code, the missing games are now displayed. But as you said, if two favorites play against each other now, they will be shown twice.
Iām not sure what you mean by the only way is like I wrote above in a complicated template
And why are the home team right. I think the home team must be left. In the favorites I can change it. But not in Pregame, Live and Postgame.
Home teams are normally on the right.
Look at the data ā¦ it is like āSEA @ DALā which is home team right.
You can change it and make it home team left, it is in the template.
The reason why it is a hugely complicated template is really evident if you look at it.
You are only providing a list of team sensors.
Nothing knows who is playing who.
You have to take all your favorites, look up who they are playing and if they are playing another favorite, donāt display (one of) the games. That data is not readily available and has be be analyzed from the sensor and then it does not have the other sensorās name, if has like I said āSEA @ DALā.
So you need to do something to look up āDALā and find what āDALā is, then get the fact that itās name is āsensor.dallas_starsā ā¦ then you need to check if āsensor.dallas_starsā is in your favorites then if yes, display only one game.
This is very difficult at best and likely will never work without adding more things.
Like what if you have a favorite whose name is āDALā ā¦ but that is for NFL and not NHL. You would need to be sure you only look into things that are in the same sport.
I am not planning to invest that must time for now for this. At the moment, you can get every game (which includes duplicates) or only home games (which excludes a favorite Away playing a non-favorite Home). That is all
Oh sorry, here in Germany are the home team left. But now I know it, it is different in USA.
Of course I can understand that they wonāt invest so much time in it. Then Iāll leave it at me with the doublet.
At the very top of the TAML, you would have this:
game_stats:
card:
unique: true
show_empty: false
card:
card_param: cards
filter:
template: |
{%- for team in integration_entities("teamtracker") -%}
{%- if state_attr(team, "league") == "[[sport]]" -%}
{%- if states(team) == "[[status]]" -%}
"entity": team,
{%- endif -%}
{%- endif -%}
{%- endif -%}
{%- endfor -%}
exclude:
sort:
method: attribute
attribute: date
Just change home_side to āleftā
Yes I found it for the favorites. But not for Pregame, Live and Postgame.
