Sports Standings and Scores
Hello @bburwell
Indeed I do see the Team Schedules (may add the other teams so I see all), but unfortunately I do not see the scheduled games.
I digged a bit and it seems I do not have sensor.nfl_red_zone as entity which is needed when I check the code
Furthermore I guess that bit of code in the sensor is for testing purposes - seeing it’s your local HA instance?
Well shoot sorry, yeah my template file would be helpful. Just added it to github and tried to pull some of the sandbox items.
The data that Teamtracker uses is created by the sensor. For example the Washington Commanders play this weekend. So teamtracker uses this data:
- platform: teamtracker
  league_id: NFL
  team_id: WSH
  name: Washington Commanders
to create the sensor sensor.washington_commanders which the teamtracker card uses the data in there to populate the card. This is what my sensor is showing right now.
Guessing you are showing that sensor and the data, but the red_zone isn’t there.
That is why you will see in this thread for those that don’t have the NFL data, they also don’t see any data because HA hits red_zone and errors out.
Try adding the template data and let me know if that works. If it doesn’t check the sensor and let us see what you are seeing.
Indeed that works now!
So all is fine except the Overall page somehow. It does work only for WNBA + NBA and not the rest
Using e.g. sensor.nfl_*_* in dev tools it shows data
Yeah - I noticed that as well but I am not certain why yet. It is pulling the same sensor data as divisional/conference.
I’ll try to glance at it later - maybe something with the flex-table card - not sure
Updated the Sports_US_Professional dashboard on github to fix the overall tab not showing data.
I wasn’t excluding some sensors. Since we are using a wildcard on Overall (NHL/NFL) I missed that I had added team schedules to my sensors so I also had a sensor called sensor.nhl_schedule… as an example and it was trying to parse this which kept it from populating.
I am still hitting a snag with MLB and will look at it later and WNBA when the stats populate.
Hi there, I’m trying to take this same approach for the Belgan Pro League (Sports Standings and Scores - #177 by kbrown01) and apply it to tennis rankings for both the ATP & WTA (https://site.web.api.espn.com/apis/site/v2/sports/tennis/atp/rankings?region=us&lang=en)
I successfully tested the approach for the Belgian league so I know that I have everything set-up/installed correctly.
What isn’t working is that my dashboard populates with my two test columns but has 'undefinedundefinedundefined' in each of the two test fields.
I’ve created a rest sensor, which is populating data:
## ATP Rankings
- platform: rest
  scan_interval: 36000
  name: Tennis ATP Ranking
  unique_id: sensor.tennis_atp_ranking
  resource: https://site.web.api.espn.com/apis/site/v2/sports/tennis/atp/rankings?region=us&lang=en
  value_template: "{{ now() }}"
  json_attributes:
    - rankings
And I have a template sensor (which I do not believe is populating with data):
### Tennis ATP Ranking
  - name: ATP Ranking
    unique_id: sensor.tennis_atp_ranking_list
    state: "{{ now() }}"
    attributes:
      entries: "{{ state_attr('sensor.tennis_atp_ranking','rankings')[0]['ranks'] }}"
And the dashboard code which is pointing at my rest sensor:
decluttering_templates:
  bpl_settings:
    card:
      type: custom:flex-table-card
      title: '[[title]]'
      css:
        table+: 'padding: 0px; width: 1600px;'
        tbody tr td:first-child: 'width: 5%;'
        tbody tr td:nth-child(2): 'width: 30%;'
        tbody tr td:nth-child(n+3): 'width: 5%;'
        tbody tr:hover: 'background-color: green!important; color:white!important;'
      card_mod:
        style:
            ha-card {
              overflow: auto;
            .card-header {
               padding-top: 6px!important;
               padding-bottom: 4px!important;
               font-size: 14px!important;
               line-height: 14px!important;
               font-weight: bold!important;
      entities:
        include: '[[entity]]'
      sort_by: ranks
      columns:
        - name: Rank
          data: ranks
          modify: x.current
        - name: Previous
          data: ranks
          modify: x.previous
  - title: Tennis Rankings
    icon: mdi:tennis
    type: panel
    badges: []
    cards:
      - type: custom:decluttering-card
        template: bpl_settings
        variables:
          - title: ATP
          - entity: sensor.tennis_atp_ranking
I think I have two problems:
  1. my template sensor isn’t formatted correctly
  2. my dashboard code isn’t parsing the json properly
Would appreciate any help steering me in the right direction.
I am really interested to this project, so please, let me know if you get the solution. I already created the sensor and the dashboard…
@jasonkjennings - your code worked for me but as I have stated I don’t use templates and honestly you don’t need them here. Just pull the data from the sensor.
With that said a couple notes:
  • You can simplify the code by just using the sensor to jump to the level you want.
    For example here is how I wrote your sensor. (As I note earlier in this thread I use individual sensors for each sport so I created a tennis.yaml file to test what you are doing). Here is what is in my tennis.yaml file:
## ATP Rankings
- platform: rest
  json_attributes_path: "$.['rankings'][0]"
  json_attributes:
    - ranks
  • When you create the sensor you are essentially getting the data at that starting point. So I can test that in developers tools:
  • I threw your code into a sandbox dashboard and it came up with the rankings
  • Since I was looking at the sensor anyway I added a couple items for S&G’s so this is what the sandbox looks like now:
Here is the sandbox code if you want it
  bpl_settings:
    card:
      title: '[[title]]'
      css:
        tbody tr td:first-child: 'width: 3%;'
        tbody tr td:nth-child(2): 'width: 3%;'
        tbody tr td:nth-child(3): 'width: 3%;'
        tbody tr td:nth-child(n+4): 'width: 20%;'
      card_mod:
        style:
            ha-card {
              overflow: auto;
            .card-header {
      entities:
      sort_by: ranks
      columns:
        - name: Rank
          data: ranks
          modify: x.current
        - name: Previous
          data: ranks
          modify: x.previous
        - name: Country
          data: ranks
          modify: >-
            '<div>' + (typeof x.athlete.flag !== 'undefined' ? '<img src="' +
            x.athlete.flag + '"
            style="width:20px;height:20px;margin-right:5px;">' : '') +
            x.athlete.flagAltText + '</div>'
        - name: Athlete
          data: ranks
          modify: >-
            '<div>' + (typeof x.athlete.headshot !== 'undefined' ? '<img src="'
            + x.athlete.headshot + '"
            x.athlete.displayName + '</div>'
    icon: mdi:tennis
    type: panel
    badges: []
    cards:
        variables:
          - title: ATP
Can’t wait to see what you come up when you share your updates!!
Thanks so much for this!
I knew I wasn’t doing something right with parsing the json – having it in the right spot to start makes it much easier.
Thanks again, and yes, I’ll share when I get it completed – going to add tabs to toggle between the men/women’s rankings.
(and thanks for kick-starting the ‘if no flag/headshot’ is available!)
It works great, but it’s really quite impossible to see in mobile view…Is there a way to make the dashboard visible also on mobile?
What isn’t working? Is it that it is too wide and you need to squish it together?
I don’t do a lot on mobile @ehcah does maybe he has some ideas but here a squishier dashboard. You need to play with width: 400px, child widths and what you really want to show. For example you could combine rank/previous into a single column
  bpl_settings:
    card:
      title: '[[title]]'
      css:
        table+: 'padding: 0px; width: 400px;'
        tbody tr td:first-child: 'width: 1%;'
        tbody tr td:nth-child(2): 'width: 1%;'
        tbody tr td:nth-child(3): 'width: 10%;'
      card_mod:
        style:
            ha-card {
              overflow: auto;
            .card-header {
      entities:
      sort_by: ranks
      columns:
        - name: Rank
          data: ranks
          modify: x.current
        - name: Previous
          data: ranks
          modify: x.previous
        - name: Athlete
          data: ranks
          modify: >-
            '<div
            style="display:flex;justify-content:space-between;align-items:center;">'
            + '<div style="display:flex;align-items:center;">' + (typeof
            x.athlete.headshot !== 'undefined' ? '<img src="' +
            x.athlete.displayName + '</div>' + '<div>' + (typeof x.athlete.flag
            !== 'undefined' ? '(' + '<img src="' + x.athlete.flag + '"
            style="width:20px;height:20px;margin-right:5px;">' +
            x.athlete.flagAltText + ')' : '') + '</div>' + '</div>'
    icon: mdi:tennis
    type: panel
    badges: []
    cards:
        variables:
          - title: ATP
Yes, that’s what i mean…
Changing to 400px now is ok with the mobile view… but i will play with the child widths to have the best view also on mobile.
Thanks for you help…
Great. You can also mess around with the images as well.
For example doing this:
        - name: Athlete
          data: ranks
          modify: >-
            '<div
            style="width:40px;height:40px;margin-right:5px;">' : '') +
            x.athlete.displayName + '</div>' + '<div style="background-image:
            url(' + (typeof x.athlete.flag !== 'undefined' ? x.athlete.flag :
            '') + '); background-size: cover; background-repeat: no-repeat;
            height: 30px; width: 50px; display: flex; align-items: center;
            justify-content: center;">' + (typeof x.athlete.flag !== 'undefined'
            ? x.athlete.flagAltText : '') + '</div>' + '</div>'
Gives you this:
Ok, i modified the athlete option in the template, but now i get two times the flags as you can see:
And how to change the color of the name of the state?. As you see in some flags is not so clear…
EDIT: my fault… i forgot to delete the country option…
Sure, I am guessing that you have a column named Country in there. Just delete the Country Column.
In the code I posted today you can see that I deleted the Country column and moved that data into the Athlete Column. Combining those to try to free up some real estate for a mobile view.
This is what I did to make it work on mobile:
  bpl_settings:
    card:
      title: '[[title]]'
      css:
        table+: >-
          padding: 0px; width: 100%; max-width: 1600px; display: block;
          overflow-x: auto;
        tbody tr td:first-child: 'width: 0.1%; text-align: center;'
        tbody tr td:nth-child(2): 'width: 0.1%; text-align: center;'
        tbody tr td:nth-child(3): 'width: auto; text-align: center;'
        tbody tr td:nth-child(n+4): 'width: auto;'
        tbody tr:hover: 'background-color: green!important; color: white!important;'
        '@media (max-width: 600px)': |
          tbody tr td {
            font-size: 12px;
            padding: 2px;
          tbody tr td img {
            width: 15px;
            height: 15px;
      card_mod:
        style:
            ha-card {
              overflow: auto;
            .card-header {
      entities:
      sort_by: ranks
      columns:
        - name: Rk
          data: ranks
          modify: x.current
        - name: +-
          data: ranks
          modify: >-
            '<div style="color:' + (x.trend > 0 ? 'green' : x.trend < 0 ? 'red'
            : 'white') + ';">' + x.trend + '</div>'
        - name: Flag
          data: ranks
          modify: >-
            x.athlete.flag + '"
            x.athlete.citizenshipCountry + '</div>'
        - name: Name
          data: ranks
          modify: >-
            src="' + x.athlete.headshot + '"
            (x.athlete.links && x.athlete.links.find(l =>
            l.rel.includes("playercard")) ?  '<a href="' +
            x.athlete.links.find(l => l.rel.includes("playercard")).href + '"
            target="_blank" style="text-decoration: none; color: inherit;">' +
            x.athlete.displayName + '</a>'  : x.athlete.displayName) +  '</div>'
        - name: Pts
          data: ranks
          modify: x.points
    icon: mdi:tennis
    type: panel
    badges: []
    cards:
        variables:
          - title: ATP
Also, using the country abbreviation really helps.
Yes, you got it… Very nice dashboard also on mobile !
I spent a little bit trying to figure out the api behind this page (ATP Schedule - 2025 Season - ESPN) but was unsuccessful - I was going to put in the upcoming tournaments as well.
Any chance to have also a WTA dashboard like ATP?
This coul be very useful and interesting…
The code is basically the same for your sensor just add a wta sensor.
## WTA Rankings
- platform: rest
  name: Tennis WTA Ranking
  unique_id: sensor.tennis_wta_ranking
  resource: https://site.web.api.espn.com/apis/site/v2/sports/tennis/wta/rankings?region=us&lang=en
  json_attributes:
    - ranks
I don’t follow tennis, but you might want to check some of the more common ESPN API’s that are called out in this forum. For example, you might be able to pull some data from the scoreboard API. Here is an example for ATP but you could add a WTA sensor as well. I don’t know what data is in there or will be but just another avenue.
## ATP Scoreboard
- platform: rest
  name: Tennis ATP Scoreboard
  unique_id: sensor.tennis_atp_scoreboard
  resource: https://site.web.api.espn.com/apis/site/v2/sports/tennis/atp/scoreboard
  json_attributes:
    - leagues
    - season
    - day
    - events
Most of us have built our sports dashboards on tabs so as you add more data you may want to move to tabs to include teamtracker cards. You can start with something like this:
  bpl_settings:
    card:
      title: '[[title]]'
      css:
        tbody tr td:nth-child(3): 'width: 20%;'
      card_mod:
        style:
            ha-card {
              overflow: auto;
            .card-header {
      entities:
      sort_by: ranks
      columns:
        - name: Rank
          data: ranks
          modify: x.current
        - name: Previous
          data: ranks
          modify: x.previous
        - name: Athlete
          data: ranks
          modify: >-
            '<div
        - name: Pts
          data: ranks
          modify: x.points
  - theme: Backend-selected
    title: Sports
    type: panel
    icon: mdi:strategy
    badges: []
    cards:
      - type: custom:mod-card
        card_mod:
          style:
            tabbed-card $: |
              mwc-tab {
                background: black;
                color: silver;
                border-color: var(--ha-card-border-color, var(--divider-color, #e0e0e0));
                border-width: 2px;
                border-style: solid;
                overflow: hidden;
                width: 20%;
              mwc-tab[active] {
                background: white !important;
                color: black !important;
        card:
          type: custom:tabbed-card
          styles:
            '--mdc-theme-primary': black
            '--mdc-tab-text-label-color-default': silver
            '--mdc-typography-button-font-size': 12px
          tabs:
            - attributes:
                label: Tennis
                icon: mdi:tennis
              card:
                card_mod:
                  style:
                    tabbed-card $: |
                      mwc-tab {
                        background: black;
                        border-color: silver;
                        border-width: 2px;
                        border-top-left-radius: 20px;
                        border-top-right-radius: 20px;
                        overflow: hidden;
                        width: 15%;
                      mwc-tab[active] {
                card:
                  card_mod:
                    style:
                      tabbed-card $: |
                        mwc-tab {
                          background: black;
                          border-width: 2px;
                          overflow: hidden;
                          width: 10%;
                        mwc-tab[active] {
                  tabs:
                    - attributes:
                        label: Leagues
                        icon: mdi:tennis-ball
                      card:
                        card_mod:
                          style:
                            tabbed-card $: |
                              mwc-tab {
                                background: black;
                                border-width: 2px;
                                overflow: hidden;
                                width: 5%;
                              mwc-tab[active] {
                        card:
                          styles:
                          tabs:
                            - attributes:
                                label: Men's Tennis
                                icon: mdi:account-group
                              card:
                                type: horizontal-stack
                                cards:
                                  - type: vertical-stack
                                    cards:
                                      - type: markdown
                                        content: |
                                          <h1>ATP Rankings</h1>
                                        variables:
                                          - title: ATP
                            - attributes:
                                label: Women's Tennis
                              card:
                                cards:
                                    cards:
                                      - type: markdown
                                        content: |
                                          <h1>WTA Rankings</h1>
                                        variables:
                                          - title: WTA
                                          - entity: sensor.tennis_wta_ranking
Looking forward to what you guys create.
