I upgraded HACS to 0.14.2 an hour ago or so. So I am already running on that version.
I saw the .DS_store sneeked in. I removed it and will do a new release tomorrow as I canāt do it on mobile for some reason (girhub hides it I guess)
Iāve now released 2.2 which should work with HACS (deleted the .DS_Store). I donāt know if it fixes it yet because I need to upgrade HACS and wait for it to update the data.
If some kind soul can test it and update it here I would be greatful as I need to rush away for some hours
It works for HACS 0.14.2 at least, but so does 2.1 so that was probably not a good test
2.1 didnāt work to me on hacs 14.2 BUT 2.2 does. So great work!
2.2 works fine! Thanks!
Great job on this custom component! New shuffle and " transfer current playback" is great!
Thanks for the nice feedback. There is a hidden feature Iām random playlist if you are interested (search this topic. It is not that secret
If everybody that liked the component can star it on github it would be great
Ahhh. Thanks for the tip. Random playlist may be useful. Why isnt it documented?
@fondberg hey mate! First, thanks a lot for the awesome work. This component is a game changer.
On to the bad stuff:
Is there any issue with the component on the latest release of Hassio? Iāve been getting this error: "name='wp_access_token', domain=None, path=None"
whenever I try to use spotcast.start, on previously tested and working stuff.
Cheers!
@vlad.bisceanu I have the same issue, driving me nuts. @fondberg what to do?
Running hass.io 0.99.3 and spotcast 2.2
Tbh I think this might be related to Spotify making a change, rather than this component. Iāve just today noticed that the Spotify player doesnāt show any cast devices on my network anymore as options to cast to.
@Catt00 can you check and see if this is also true for you?
Cheers!
My SpotifyConnect devices are working and showing as before. And no errors when i playing on those.
Same problem here, running Hass.io 0.99.3 and spotcast 2.2.
This is the full traceback:
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 130, in handle_call_service
connection.context(msg),
File "/usr/src/homeassistant/homeassistant/core.py", line 1234, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1259, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 142, in service_handler
await script.async_turn_on(variables=service.data, context=service.context)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 214, in async_turn_on
raise err
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 209, in async_turn_on
await self.script.async_run(kwargs.get(ATTR_VARIABLES), context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 162, in async_run
await self._handle_action(action, variables, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 246, in _handle_action
await self._actions[_determine_action(action)](action, variables, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 329, in _async_call_service
context=context,
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 98, in async_call_from_config
domain, service_name, service_data, blocking=blocking, context=context
File "/usr/src/homeassistant/homeassistant/core.py", line 1261, in _execute_service
await self._hass.async_add_executor_job(handler.func, service_call)
File "/config/custom_components/spotcast/__init__.py", line 162, in start_casting
access_token, expires = get_spotify_token(username=user, password=pwd)
File "/config/custom_components/spotcast/__init__.py", line 85, in get_spotify_token
data = st.start_session(username, password)
File "/usr/local/lib/python3.7/site-packages/spotify_token.py", line 70, in start_session
access_token, expiration_date = _get_access_token(session, cookies)
File "/usr/local/lib/python3.7/site-packages/spotify_token.py", line 42, in _get_access_token
access_token = response.cookies['wp_access_token']
File "/usr/local/lib/python3.7/site-packages/requests/cookies.py", line 328, in __getitem__
return self._find_no_duplicates(name)
File "/usr/local/lib/python3.7/site-packages/requests/cookies.py", line 399, in _find_no_duplicates
raise KeyError('name=%r, domain=%r, path=%r' % (name, domain, path))
KeyError: "name='wp_access_token', domain=None, path=None"
Great component, thanks. The spotify app on Chromecast does not seem to load properly sometimes, or most of the times when it just starts. I see the Spotify logo and after a while the Chromecast goed back to the ādesktopā screen. I think it has to do with the Chromecast, and not this component. Does anyone has the same issue?
(If I relaunch the service call it show the Spotify logo again and it starts playing almost immediately)
Hi, I have a question, I love your component but the Spotify part is driving me crazy. Could I use your component with Google Music? Since I have google assistant webserver installed and working, could I use your component to start a playlist defined with this addon? I mean, can I give the order "http://localhassioip:5000/command?message=play%someplaylist%20% and somehow use your component to select where? I know I could include the rest of the instruction in the command, but I have almost 10 chromecasts + groups, so it would be better if I can send the āwhereā part with your component. Tks
Thanks for a great component!
Getting similar errors as bruring and vlad.bisceanu mentions above.
Running .99.0 and have tried Spotcast 2.2 and 2.1
I have the same issue as Bruring and Vlad. I opened a issue on github. Feel free to add information there.
Hi, unfortunately some time over the last few days Spotcast has stopped working. It has been working flawlessly for ages. Iām running Hassio 0.98 so I dont think it is the new Hassio. Not sure how to check which version of spotcast iām running.
Cheers
