After updating Spotcast to v3.5.10, I experience a delay of about 10 seconds between triggering the automation and start playing the music. Before, this was almost instant. Someone recognizes this?
does multiple accounts works ?
i have the keys and following the instructions (spotcast & spotify)
spotcast 3.5.10
HA core-2021.5.5
but i cant get it to work
(default is orking fine)
I’m use spotcast shuffle true in a playlist 800 musics.
But, it always play a very similar sequence.
Does anyone knows how to do play completely different tracks sequence each script run?
My code:
- service: spotcast.start
device_name: Double Room Speaker
uri: 'spotify:playlist:1OzvWussrGr2llMIcTazyP'
shuffle: true
I tryed too:
sequence:
device_name: Bathroom Speaker
shuffle: true
- service: media_player.shuffle_set
entity_id: media_player.spotify
shuffle: true
- wait_template: "{{ is_state('media_player.bathroom_speaker', 'playing') }}"
- delay: '00:00:04'
- service: media_player.media_next_track
Shuffle is for the next song. Not the first. Try random and shuffle
See the readme. There are examples
This must be caused by something else because the fallback to searching for cast devices in Spotcast is gone and that is the only thing that took time.
Turn on the debug logs. What I can guess is that the spotify app on the cast device is slow. Try another device
I was wrong. These are hard to support in spotcast as it is not a media_player. I thought you meant playback offset.
Guys, anyone seeing this error too:
Log Details (ERROR)
This error originated from a custom integration.
Logger: homeassistant.setup
Source: custom_components/spotcast/spotcast_controller.py:160
Integration: spotcast ([documentation](https://github.com/fondberg/spotcast), [issues](https://github.com/fondberg/spotcast/issues))
First occurred: 10:42:10 PM (1 occurrences)
Last logged: 10:42:10 PM
Error during setup of component spotcast
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/setup.py", line 248, in _async_setup_component result = await task File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run result = self.fn(*self.args, **self.kwargs) File "/config/custom_components/spotcast/__init__.py", line 51, in setup spotcast_controller = SpotcastController(hass, sp_dc, sp_key, accounts) File "/config/custom_components/spotcast/spotcast_controller.py", line 160, in __init__ accounts["default"] = OrderedDict([("sp_dc", sp_dc), ("sp_key", sp_key)]) TypeError: 'NoneType' object does not support item assignment
Update to the latest version ( .13 , not any lower as the issue exists in .11 and .12 too)
solved in the latest release
help, i cant get account freja and frede to work, - but the default (mine) is working fine
what am i doing wrong? when im using the default it shows me my chromecast devices
OK thank you anyway for looking into it.
Hey all. Got this component in and loading, i love it. But im stuck on how to make its output devices let me do playback on one (or more) of my Sonos at the same time. I dont see any of them showing up in the playback device list
Read the README. Tldr; sonos os not supported
i am getting these errors now, what does it mean? mine spotify it still working
2021-07-26 08:57:23 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/config/custom_components/spotcast/spotcast_controller.py", line 142, in get_spotify_token
self._access_token, self._token_expires = st.start_session(
File "/usr/local/lib/python3.9/site-packages/spotify_token.py", line 18, in start_session
response = session.get("https://open.spotify.com/get_access_token?reason=transport&productType=web_player",
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 555, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 677, in send
history = [resp for resp in gen]
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 677, in <listcomp>
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 166, in resolve_redirects
raise TooManyRedirects('Exceeded {} redirects.'.format(self.max_redirects), response=resp)
requests.exceptions.TooManyRedirects: Exceeded 30 redirects.
File "/config/custom_components/spotcast/helpers.py", line 60, in run
return await loop.run_in_executor(executor, pfunc)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/config/custom_components/spotcast/__init__.py", line 78, in get_devices
client = spotcast_controller.get_spotify_client(account)
File "/config/custom_components/spotcast/spotcast_controller.py", line 176, in get_spotify_client
return spotipy.Spotify(auth=self.get_token_instance(account).access_token)
File "/config/custom_components/spotcast/spotcast_controller.py", line 136, in access_token
self.ensure_token_valid()
File "/config/custom_components/spotcast/spotcast_controller.py", line 132, in ensure_token_valid
self.get_spotify_token()
File "/config/custom_components/spotcast/spotcast_controller.py", line 148, in get_spotify_token
raise HomeAssistantError("Could not get spotify token")
homeassistant.exceptions.HomeAssistantError: Could not get spotify token
i think your sp_key and sp_dc are old
indeed, renewed and fixed
Seems I’m having issues since updating to HA 2021.8.6 (container)
I checked the sp_dc & sp_key - both match from config to browser settings. Tried re-installing the integration - no luck. Any other suggestions?
Error executing service: <ServiceCall spotcast.start ( *redacted - can include if necessary* ): uri=https://open.spotify.com/playlist/37i9dQZF1DX2Nc3B70tvx0?si=5d235b17288e4dab, random_song=True, shuffle=True, entity_id=media_player.google_home, ignore_fully_played=False, repeat=off, force_playback=False, start_volume=101, offset=0>
File "/usr/src/homeassistant/homeassistant/core.py", line 1507, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1530, in _execute_service
await self._hass.async_add_executor_job(handler.job.target, service_call)
File "/config/custom_components/spotcast/__init__.py", line 143, in start_casting
spotify_device_id = spotcast_controller.get_spotify_device_id(
File "/config/custom_components/spotcast/spotcast_controller.py", line 202, in get_spotify_device_id
spotify_cast_device.startSpotifyController(access_token, expires)
File "/config/custom_components/spotcast/spotcast_controller.py", line 84, in startSpotifyController
sp.launch_app()
File "/usr/local/lib/python3.9/site-packages/pychromecast/controllers/spotify.py", line 87, in launch_app
raise LaunchError(
pychromecast.error.LaunchError: Timeout when waiting for status response from Spotify app
After update Home Assistant - same here. Turning on/off players, reinstal addon, restart HA. This same problem
Suddenly seeing the same issue here:
2021-08-12 16:45:46 DEBUG (SyncWorker_6) [custom_components.spotcast.spotcast_controller] setting up with account t
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.spotcast_controller] expires: 1628782846 time: 1628779547.0107527
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.spotcast_controller] setting up with account t
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.helpers] get_spotify_devices: media_player.spotify_t: Spotify T: []
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.helpers] get_spotify_devices: {'devices': []}
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.helpers] get_cast_devices: media_player.woonkamer: Woonkamer cast info: ChromecastInfo(services={ServiceInfo(type='mdns', data='google-nest-hub-4660f5b8aabe10031a93ebd362367256-1._googlecast._tcp.local.'), ServiceInfo(type='host', data=('192.168.xx.16', 8009))}, uuid='4660f5b8-aabe-1003-1a93-ebd362367256', _manufacturer='Google Inc.', model_name='Google Nest Hub', friendly_name='Woonkamer', is_audio_group=False, is_dynamic_group=None)
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.helpers] get_cast_devices: media_player.soundbar: Soundbar cast info: ChromecastInfo(services={ServiceInfo(type='mdns', data='.xx.5-81704a75fd037a7c38090eb3c5dffea5._googlecast._tcp.local.')}, uuid='81704a75-fd03-7a7c-3809-0eb3c5dffea5', _manufacturer=None, model_name='.xx.5', friendly_name='Soundbar', is_audio_group=False, is_dynamic_group=None)
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.helpers] get_cast_devices: media_player.slaapkamer: Slaapkamer cast info: ChromecastInfo(services={ServiceInfo(type='host', data=('192.168.xx.13', 8009)), ServiceInfo(type='mdns', data='Google-Home-Mini-0256c1dd13b44c80849b281970d02d11-1._googlecast._tcp.local.'), ServiceInfo(type='mdns', data='Google-Home-Mini-0256c1dd13b44c80849b281970d02d11._googlecast._tcp.local.'), ServiceInfo(type='mdns', data='Google-Home-Mini-0256c1dd13b44c80849b281970d02d11-2._googlecast._tcp.local.')}, uuid='0256c1dd-13b4-4c80-849b-281970d02d11', _manufacturer='Google Inc.', model_name='Google Home Mini', friendly_name='Slaapkamer', is_audio_group=False, is_dynamic_group=None)
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.helpers] get_cast_devices: media_player.studeerkamer: Studeerkamer cast info: ChromecastInfo(services={ServiceInfo(type='mdns', data='Google-Home-d4063db0253e246c9d66d8f7fda77a6a-2._googlecast._tcp.local.'), ServiceInfo(type='host', data=('192.168.xx.12', 8009)), ServiceInfo(type='mdns', data='Google-Home-d4063db0253e246c9d66d8f7fda77a6a._googlecast._tcp.local.')}, uuid='d4063db0-253e-246c-9d66-d8f7fda77a6a', _manufacturer='Google Inc.', model_name='Google Home', friendly_name='Studeerkamer', is_audio_group=False, is_dynamic_group=None)
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.helpers] get_cast_devices: media_player.hele_huis: Hele huis cast info: ChromecastInfo(services={ServiceInfo(type='mdns', data='Google-Cast-Group-eec4b1d472ec428fad8f291a69a2d97d-1._googlecast._tcp.local.'), ServiceInfo(type='host', data=('192.168.xx.12', 32059)), ServiceInfo(type='mdns', data='Google-Cast-Group-eec4b1d472ec428fad8f291a69a2d97d._googlecast._tcp.local.')}, uuid='eec4b1d4-72ec-428f-ad8f-291a69a2d97d', _manufacturer=None, model_name='Google Cast Group', friendly_name='Hele huis', is_audio_group=True, is_dynamic_group=False)
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.helpers] get_cast_devices: media_player.boven: Boven cast info: ChromecastInfo(services={ServiceInfo(type='mdns', data='Google-Cast-Group-e18cddf284be43da9917ddb7d4ceb42c-1._googlecast._tcp.local.'), ServiceInfo(type='mdns', data='Google-Cast-Group-e18cddf284be43da9917ddb7d4ceb42c._googlecast._tcp.local.'), ServiceInfo(type='host', data=('192.168.xx.12', 32213))}, uuid='e18cddf2-84be-43da-9917-ddb7d4ceb42c', _manufacturer=None, model_name='Google Cast Group', friendly_name='Boven', is_audio_group=True, is_dynamic_group=False)
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.helpers] get_cast_devices: media_player.zolder: Zolder cast info: ChromecastInfo(services={ServiceInfo(type='mdns', data='Google-Home-Mini-71d8c580bbd0166b72f10071a427b6cb-1._googlecast._tcp.local.'), ServiceInfo(type='host', data=('[::ffff:c0a8:5811]', 8009)), ServiceInfo(type='mdns', data='Google-Home-Mini-71d8c580bbd0166b72f10071a427b6cb._googlecast._tcp.local.'), ServiceInfo(type='host', data=('192.168.xx.17', 8009)), ServiceInfo(type='mdns', data='Google-Home-Mini-71d8c580bbd0166b72f10071a427b6cb-2._googlecast._tcp.local.')}, uuid='71d8c580-bbd0-166b-72f1-0071a427b6cb', _manufacturer='Google Inc.', model_name='Google Home Mini', friendly_name='Zolder', is_audio_group=False, is_dynamic_group=None)
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.helpers] get_cast_devices: media_player.tv_beneden: TV Beneden cast info: ChromecastInfo(services={ServiceInfo(type='mdns', data='TPM191E-bec0597.xx.b9a0a6966437ba87df4fe._googlecast._tcp.local.')}, uuid='bec05970.xx.b-9a0a-6966-437ba87df4fe', _manufacturer=None, model_name='TPM191E', friendly_name='TV Beneden', is_audio_group=False, is_dynamic_group=None)
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.helpers] get_cast_devices: media_player.tv_slaapkamer: TV Slaapkamer cast info: ChromecastInfo(services={ServiceInfo(type='mdns', data='Chromecast-32e39183bc97abac51d77fce98a766a4._googlecast._tcp.local.')}, uuid='32e39183-bc97-abac-51d7-7fce98a766a4', _manufacturer=None, model_name='Chromecast', friendly_name='TV Slaapkamer', is_audio_group=False, is_dynamic_group=None)
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.spotcast_controller] Chromecast devices: [ChromecastInfo(services={ServiceInfo(type='mdns', data='google-nest-hub-4660f5b8aabe10031a93ebd362367256-1._googlecast._tcp.local.'), ServiceInfo(type='host', data=('192.168.xx.16', 8009))}, uuid='4660f5b8-aabe-1003-1a93-ebd362367256', _manufacturer='Google Inc.', model_name='Google Nest Hub', friendly_name='Woonkamer', is_audio_group=False, is_dynamic_group=None), ChromecastInfo(services={ServiceInfo(type='mdns', data='.xx.5-81704a75fd037a7c38090eb3c5dffea5._googlecast._tcp.local.')}, uuid='81704a75-fd03-7a7c-3809-0eb3c5dffea5', _manufacturer=None, model_name='.xx.5', friendly_name='Soundbar', is_audio_group=False, is_dynamic_group=None), ChromecastInfo(services={ServiceInfo(type='host', data=('192.168.xx.13', 8009)), ServiceInfo(type='mdns', data='Google-Home-Mini-0256c1dd13b44c80849b281970d02d11-1._googlecast._tcp.local.'), ServiceInfo(type='mdns', data='Google-Home-Mini-0256c1dd13b44c80849b281970d02d11._googlecast._tcp.local.'), ServiceInfo(type='mdns', data='Google-Home-Mini-0256c1dd13b44c80849b281970d02d11-2._googlecast._tcp.local.')}, uuid='0256c1dd-13b4-4c80-849b-281970d02d11', _manufacturer='Google Inc.', model_name='Google Home Mini', friendly_name='Slaapkamer', is_audio_group=False, is_dynamic_group=None), ChromecastInfo(services={ServiceInfo(type='mdns', data='Google-Home-d4063db0253e246c9d66d8f7fda77a6a-2._googlecast._tcp.local.'), ServiceInfo(type='host', data=('192.168.xx.12', 8009)), ServiceInfo(type='mdns', data='Google-Home-d4063db0253e246c9d66d8f7fda77a6a._googlecast._tcp.local.')}, uuid='d4063db0-253e-246c-9d66-d8f7fda77a6a', _manufacturer='Google Inc.', model_name='Google Home', friendly_name='Studeerkamer', is_audio_group=False, is_dynamic_group=None), ChromecastInfo(services={ServiceInfo(type='mdns', data='Google-Cast-Group-eec4b1d472ec428fad8f291a69a2d97d-1._googlecast._tcp.local.'), ServiceInfo(type='host', data=('192.168.xx.12', 32059)), ServiceInfo(type='mdns', data='Google-Cast-Group-eec4b1d472ec428fad8f291a69a2d97d._googlecast._tcp.local.')}, uuid='eec4b1d4-72ec-428f-ad8f-291a69a2d97d', _manufacturer=None, model_name='Google Cast Group', friendly_name='Hele huis', is_audio_group=True, is_dynamic_group=False), ChromecastInfo(services={ServiceInfo(type='mdns', data='Google-Cast-Group-e18cddf284be43da9917ddb7d4ceb42c-1._googlecast._tcp.local.'), ServiceInfo(type='mdns', data='Google-Cast-Group-e18cddf284be43da9917ddb7d4ceb42c._googlecast._tcp.local.'), ServiceInfo(type='host', data=('192.168.xx.12', 32213))}, uuid='e18cddf2-84be-43da-9917-ddb7d4ceb42c', _manufacturer=None, model_name='Google Cast Group', friendly_name='Boven', is_audio_group=True, is_dynamic_group=False), ChromecastInfo(services={ServiceInfo(type='mdns', data='Google-Home-Mini-71d8c580bbd0166b72f10071a427b6cb-1._googlecast._tcp.local.'), ServiceInfo(type='host', data=('[::ffff:c0a8:5811]', 8009)), ServiceInfo(type='mdns', data='Google-Home-Mini-71d8c580bbd0166b72f10071a427b6cb._googlecast._tcp.local.'), ServiceInfo(type='host', data=('192.168.xx.17', 8009)), ServiceInfo(type='mdns', data='Google-Home-Mini-71d8c580bbd0166b72f10071a427b6cb-2._googlecast._tcp.local.')}, uuid='71d8c580-bbd0-166b-72f1-0071a427b6cb', _manufacturer='Google Inc.', model_name='Google Home Mini', friendly_name='Zolder', is_audio_group=False, is_dynamic_group=None), ChromecastInfo(services={ServiceInfo(type='mdns', data='TPM191E-bec0597.xx.b9a0a6966437ba87df4fe._googlecast._tcp.local.')}, uuid='bec05970.xx.b-9a0a-6966-437ba87df4fe', _manufacturer=None, model_name='TPM191E', friendly_name='TV Beneden', is_audio_group=False, is_dynamic_group=None), ChromecastInfo(services={ServiceInfo(type='mdns', data='Chromecast-32e39183bc97abac51d77fce98a766a4._googlecast._tcp.local.')}, uuid='32e39183-bc97-abac-51d7-7fce98a766a4', _manufacturer=None, model_name='Chromecast', friendly_name='TV Slaapkamer', is_audio_group=False, is_dynamic_group=None)]
2021-08-12 16:45:47 DEBUG (SyncWorker_6) [custom_components.spotcast.spotcast_controller] cast info: ChromecastInfo(services={ServiceInfo(type='host', data=('192.168.xx.13', 8009)), ServiceInfo(type='mdns', data='Google-Home-Mini-0256c1dd13b44c80849b281970d02d11-1._googlecast._tcp.local.'), ServiceInfo(type='mdns', data='Google-Home-Mini-0256c1dd13b44c80849b281970d02d11._googlecast._tcp.local.'), ServiceInfo(type='mdns', data='Google-Home-Mini-0256c1dd13b44c80849b281970d02d11-2._googlecast._tcp.local.')}, uuid='0256c1dd-13b4-4c80-849b-281970d02d11', _manufacturer='Google Inc.', model_name='Google Home Mini', friendly_name='Slaapkamer', is_audio_group=False, is_dynamic_group=None)
2021-08-12 16:45:50 DEBUG (SyncWorker_6) [custom_components.spotcast.spotcast_controller] Found cast device: Chromecast(None, port=8009, device=DeviceStatus(friendly_name='Slaapkamer', model_name='Google Home Mini', manufacturer='Google Inc.', uuid='0256c1dd-13b4-4c80-849b-281970d02d11', cast_type='audio'))
2021-08-12 16:46:04 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall spotcast.start (c:999e546c4febe44ced7365721538eaee): account=t, entity_id=media_player.slaapkamer, uri=spotify:track:5OoSxUZSbP1p7kb1d0SozG, offset=0, shuffle=False, start_volume=101, ignore_fully_played=False, repeat=off, random_song=False, force_playback=False>
await coro_or_task
sp.launch_app()
raise LaunchError(
Created a Github issue for it:
