Is anyone having problems with the latest release of Spotcast?
In my log i am said unable to load spotcast integration, while the previous release is working good as reverting back to this i have no more errors in log and the integration works again…
In my case the integration is not loaded at boot at all showing the error… I repeat this happens only after updating the component to the latest release. Reverting back to the previous all Is ok…
This is what i get in logs after updating to the 3.1.18 release of spotcast:
2021-10-31 15:22:33 ERROR (SyncWorker_1) [custom_components.spotcast.helpers] spotify integration not found
2021-10-31 15:22:33 ERROR (SyncWorker_1) [custom_components.spotcast] Spotify integration was not found, aborting setup...
2021-10-31 15:22:33 ERROR (MainThread) [homeassistant.setup] Setup failed for spotcast: Integration failed to initialize.
2021-10-31 15:22:33 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform spotcast.sensor: Unable to set up component.
But the spotify integration is regularly installed and running…
Did this ever get sorted out? Im having the same issue.
