Spotify Config
Thank you to @happyleavesaoc for this.
Configured as it says in the Spotify components web page and when this pops up.
I select the link and it gives back on a web browser.
INVALID_CLIENT: Invalid redirect URI
I have filled in the URL redirect with https://my_ip_address/api/spotify
(and i did save it after)
my_ip_address is the one i use to link to HA.
Update
Looked at the URL of the INVALID_CLIENT: Invalid redirect URI
and it gives my local ip address
redirect_uri=https%3A%2F%2F192.168.1.22
When i type into a new browser https://192.168.1.22 i get NOT SECURE.
Im having the same issues
Add your local IP in the Spotify Redirect URI:
http://192.168.10.80:8123/api/spotify
Worked fine for me.
/Ola
Nope still gives the INVALID_CLIENT:
&response_type=code&redirect_uri=https%3A%2F%2F192.168.1.22%3A8123%2Fapi%2Fspotify&scope=user-modify-playback-state+user-read-playback-state
Dont no why its got https:// in the feedback because i put in the redirect URL http://192.168.1.22:8123/api/spotify.
I am using a secure connection to my HA letsencrypt.
I just had same error but on checking the spotify app page I can see when I copy pasted my local address it did a double http://http://xxx and after fixing it worked - remember to save.
For me it worked with Chrome, but not with Safari.
It seems that all of you do not have a secure connection to your HA. ie: > https://xxx.duckdns.org you use http://192.168.x.x:8123/api/spotify
I have and i have tried
https://192.168.1.22:8123/api/spotify?api_password=xxxxxx
https://xxx.duck.net/api/spotify
https://xxx.duck.net/api/spotify?api_password=xxxxxx
And I did save after everyone.
In my case i forgot the port.
I used http://192.168.xxx.xxx/api/spotify which did not work.
After adding the port such as
http://192.168.xxx.xxx:8123/api/spotify it works perfect, also with Safari.
I have a secure connection and the following worked for me:
https://192.168.x.x:8123/api/spotify
I use https://mydomain:8123/api/spotify and it works.
Mydomain maps to the local ip when inside the lan, and I also have a valid letsencrypt certificate for that address when inside (and outside).
I can get to the Spotify login page, but when I click Login I get “500 internal error”
So close!
Any error in your log?
Does this help?
BTW, I’m running HA through Docker is that matters.
17-04-22 10:38:06 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/local/lib/python3.5/site-packages/aiohttp/web_protocol.py”, line 417, in start
resp = yield from self._request_handler(request)
File “/usr/local/lib/python3.5/site-packages/aiohttp/web.py”, line 289, in _handle
resp = yield from handler(request)
File “/usr/local/lib/python3.5/asyncio/coroutines.py”, line 213, in coro
res = yield from res
File “/usr/src/app/homeassistant/components/http/ban.py”, line 58, in ban_middleware_handler
return (yield from handler(request))
File “/usr/src/app/homeassistant/components/http/init.py”, line 422, in handle
result = handler(request, **request.match_info)
File “/usr/src/app/homeassistant/components/media_player/spotify.py”, line 115, in get
self.oauth.get_access_token(request.GET[‘code’])
File “/usr/local/lib/python3.5/site-packages/spotipy/oauth2.py”, line 218, in get_access_token
raise SpotifyOauthError(response.reason)
spotipy.oauth2.SpotifyOauthError: Bad Request
I have the exact same issue, but I run a “normal” install
Well managed to get it working.Its a bit extreme.
Deleted the folders. \deps\spotipy and \deps\spotipy-2.4.4-py3.4.egg-info.
Then reinstalled the last HA sudo pip3 install homeassistant==0.42.4
Rebooted
pip3 install --upgrade homeassistant
Selected the Spotify config and it went to a web page downloaded a file
but the file had nothing in it.
Went back to Chrome Downloads and looked at the file download and selected the https:// part and it worked.
I used https://xxxx.duck.net:8123/api/spotify
I am aswell just getting an empty file called “spotify” to download from the spotify API page…
I don’t get this part of your solution
“Went back to Chrome Downloads and looked at the file download and selected the https:// part and it worked.”
Could you explain what you did in detail?
Thanks in advance
TW
Select Chrome Download in the Chrome App
Click on the https:
I am getting the same error, i don’t have my homeassistant open to the internet and only use it from a local ip, are you the same? have you found a solution for this error?
I’m using Let’s Encrypt to access my HA install over the internet with .IO domain.
Still no luck.
I changed my base_url under http: to get it to work, otherwise it would just use my IP which spotify didn’t like.
