Spotify connect - not visible in source selection
Hello everyone,
I used to play music from my raspberry pi on which HA was installed using Spotify Connect addon.
On my Spotify media player card, I was able to select ‘home assistant’ as the source but it’s not visible anymore.
Here is the log when I start Spotify Connect addon:
Add-on: Spotify Connect
Play Spotify music on your Home Assistant device
Add-on version: 0.9.1
You are running the latest version of this add-on.
System: Home Assistant OS 6.2 (aarch64 / raspberrypi3-64)
Home Assistant Core: 2021.8.8
Home Assistant Supervisor: 2021.06.8
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[11:20:47] INFO: Starting the Spotify daemon…
[2021-09-01T09:20:48Z INFO librespot] librespot 0.2.0 UNKNOWN (Built on 2021-08-19, Build ID: 3UIy8sil)
I’m suspecting that my audio output on my raspberry pi might be dead, but I have no evidence to confirm this…
If anyone has an idea of what happened based on the log, please let me know.
Thanks!
Aurelien
I fixed the issue by putting my Spotify credentials in Spotify connect configuration, and not only in my configuration.yaml file.
Strange, as it was working before.
The topic can be closed.
