Spotify connect , trouble on using it
I’m new on this forum, may be this post isn’t in the correct place, let me know, please, the correct place, thanks.
I installed the Spotify Connect ADD ON version: 0.13.0 on home assistant
Add-on: Spotify Connect
Play Spotify music on your Home Assistant device
Add-on version: 0.13.0
You are running the latest version of this add-on.
System: Home Assistant OS 14.1 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2025.1.0
Home Assistant Supervisor: 2024.12.3
The description of my problem:
In a seldom way it stops the music playing, then I need to go on the Spotify App, restart the music playing and the reselect the output redirecting it.
Below the log from Spotify Connect:
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun spotifyd (no readiness notification)
[17:53:52] INFO: Starting the Spotify daemon…
s6-rc: info: service legacy-services successfully started
[2025-01-04T16:53:52Z INFO librespot] librespot 0.4.2 UNKNOWN (Built on 2024-01-06, Build ID: UYt0DULz, Profile: release)
[2025-01-04T16:54:13Z WARN librespot_core::apresolve] Ignoring blacklisted access point ap-gew4.spotify.com:4070
[2025-01-04T16:54:13Z WARN librespot_core::apresolve] Ignoring blacklisted access point ap-gew4.spotify.com:443
[2025-01-04T16:54:13Z WARN librespot_core::apresolve] Ignoring blacklisted access point ap-gew4.spotify.com:80
[2025-01-04T16:54:13Z INFO librespot_core::session] Connecting to AP “ap-guc3.spotify.com:4070
[2025-01-04T16:54:14Z INFO librespot_core::session] Authenticated as “oysv4ha7s84q6uw318qlph9sw” !
[2025-01-04T16:54:14Z INFO librespot_playback::mixer::softmixer] Mixing with softvol and volume control: Log(60.0)
[2025-01-04T16:54:14Z INFO librespot_playback::convert] Converting with ditherer: tpdf
[2025-01-04T16:54:14Z INFO librespot_playback::audio_backend::pulseaudio] Using PulseAudioSink with format: S16
[2025-01-04T16:54:14Z INFO librespot_core::session] Country: “IT”
[2025-01-04T16:54:15Z INFO librespot_playback::player] Loading with Spotify URI spotify:track:2LxEIWrZkzfc55c3rk05DH
[2025-01-04T16:54:17Z INFO librespot_playback::player] (180933 ms) loaded
[2025-01-04T16:56:10Z INFO librespot_playback::player] Loading with Spotify URI spotify:track:4JtZrQAJ4zTQPJel7LMoCX
[2025-01-04T16:56:10Z INFO librespot_playback::player] (176573 ms) loaded
[2025-01-04T16:58:14Z ERROR librespot_core::session] Connection reset by peer (os error 104)
[2025-01-04T16:58:14Z ERROR librespot_connect::spirc] subscription terminated
[*[2025-01-04T16:58:14Z WARN librespot] Spirc shut down unexpectedly**
[2025-01-04T16:58:14Z WARN librespot_core::apresolve] Ignoring blacklisted access point ap-gew4.spotify.com:4070
[2025-01-04T16:58:14Z WARN librespot_core::apresolve] Ignoring blacklisted access point ap-gew4.spotify.com:443
[2025-01-04T16:58:14Z WARN librespot_core::apresolve] Ignoring blacklisted access point ap-gew4.spotify.com:80
[2025-01-04T16:58:14Z INFO librespot_core::session] Connecting to AP “ap-guc3.spotify.com:4070
[2025-01-04T16:58:15Z INFO librespot_core::session] Authenticated as “oysv4ha7s84q6uw318qlph9sw” !
[2025-01-04T16:58:15Z INFO librespot_playback::mixer::softmixer] Mixing with softvol and volume control: Log(60.0)
[2025-01-04T16:58:15Z INFO librespot_playback::convert] Converting with ditherer: tpdf
[2025-01-04T16:58:15Z INFO librespot_playback::audio_backend::pulseaudio] Using PulseAudioSink with format: S16
[2025-01-04T16:58:15Z INFO librespot_core::session] Country: “IT”
[2025-01-04T17:01:12Z INFO librespot_playback::player] Loading with Spotify URI spotify:track:4JtZrQAJ4zTQPJel7LMoCX
What I already did, regrettably without positive results :
  • Uninstall and reinstall the Add on
  • I placed my user name & the password of my Spotify Account (premium family type)
I’ll wait for a way to investigate , so, I’m avalable to furnish firther information.
Thanks in advance.
Hi urkadurka,
What hardware are you running this on? could it be cpu/memory issue?
Hello, I’m using a Raspeberry PI4.
Below a picture to measure the overall load, I took it and in the meanwil Spotify Connect was running.
Thanks.
