[FIXED] It was a DNS issue in my case, a reboot fixed it …
I just had the same problem. I’ve noticed that when I got the 500 error on the browser after trying to add the integration, there would be a new error on the logs with Cannot connect to host accounts.spotify.com:443 (full log entry below)
Since this looked like a name resolution issue, I logged into the HA instance via SSH and tried a simple lookup:
$ nslookup accounts.spotify.com
;; connection timed out; no servers could be reached
Indeed, something’s out of whack with DNS in the instance. Not knowing much about troubleshooting DNS in a dockerized environment, I just restarted the host, and that solved the problem.
Name lookup now working:
Server: 127.0.0.11
Address: 127.0.0.11#53
Non-authoritative answer:
accounts.spotify.com canonical name = edge-web-split-geo.dual-gslb.spotify.com.
Address: 35.186.224.25
Address: 2600:1901:1:c36::
And I was able to complete the configuration of the Spotify integration.
For reference, this is the full error entry which caught my attention and made me check DNS resolution:
Log Details (ERROR)
Logger: aiohttp.server
Source: helpers/config_entry_oauth2_flow.py:197
First occurred: 6:22:35 PM (2 occurrences)
Last logged: 6:22:45 PM
Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 999, in _create_direct_connection
hosts = await asyncio.shield(host_resolved)
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 865, in _resolve_host
addrs = await self._resolver.resolve(host, port, family=self._family)
File "/usr/local/lib/python3.8/site-packages/aiohttp/resolver.py", line 31, in resolve
infos = await self._loop.getaddrinfo(
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 825, in getaddrinfo
return await self.run_in_executor(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/socket.py", line 918, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 74, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 135, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 131, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 146, in get
return await super().get(request, flow_id)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 95, in get
result = await self._flow_mgr.async_configure(flow_id)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 199, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 257, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 298, in async_step_creation
token = await self.flow_impl.async_resolve_external_data(self.external_data)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 169, in async_resolve_external_data
return await self._token_request(
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 197, in _token_request
resp = await session.post(self.token_url, data=data)
File "/usr/local/lib/python3.8/site-packages/aiohttp/client.py", line 520, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 535, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 892, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.8/site-packages/aiohttp/connector.py", line 1011, in _create_direct_connection
raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host accounts.spotify.com:443 ssl:default [Try again]
