Spotify integration and local network
Hi!
My HA is configured with a public DNS address.
On my local network, the local DNS server is configured so that this public address also works locally.
However, when configuring the spotify add-on, for some reason, I had to login on hass.io with the local ip vs. DNS (on local network).
indeed, when https://my.dns.com/api/config/config_entries/flow was called for spotify using my DNS address, it responded with:
  description_placeholders: {
    docs_url: "https://www.home-assistant.io/more-info/no-url-available"
  flow_id: "xxxxxxxxxx",
  handler: "spotify",
  reason: "no_url_available",
  type: "abort"
I have the same problem.
setting internal_url: in config didn’t fix it either…
