Having trouble getting a refreshed list of my Spotify (Liked) Playlists – rebooted HA a few times, reloaded the Spotify Integration, waited 5 mins, 1 hour, 24 hours, still only shows an outdated list of Playlists. Any thoughts? AFAIK everything is up to date. I’m aware Spotify changed their API, but not sure if that’s related.
Limited control of Google Chromecast devices. Chromecast devices are currently not fully supported by the SpotifyPlus integration. You can perform player functions (e.g. pause, resume, next track, etc) if the device is the currently active player, but you can’t wake up a device or initiate play of tracks / context.
Getting Started
make sure all requirements above have been installed.
So it seems there is/was a maximum number of playlists which could be displayed in the Spotify Integration UI? In my cased 37. I deleted a few old 'lists (in the Spotify app) then the newer Playlists are shown at the top of the HA Spotify UI.
This limit doesn’t seem to apply to Tracks, Artists, Recently Played etc. etc… only the Playlist section.
Hi, I noticed the same, quite a lot of playlists do not pop up in the overview. They seem to be the ones generated by Spotify itself. Any idea how those can be added to the overview?
@b00stman
As of November 27th 2024, Spotify removed the functionality that returns AI-generated playlists that are stored in user favorites. We were able to find a temporary way around that using the Spotify Web Player Cookie Credentials, but Spotify disabled that as well.
With that said …
Check out the reply above regarding the SpotifyPlus Integration and Card. You can create user-presets of your Spotify AI-generated favorites (Made for you, Daily Mix, Weekly Mix, etc).
