Spotify Integration – force refresh list of Playlists?
Having trouble getting a refreshed list of my Spotify (Liked) Playlists – rebooted HA a few times, reloaded the Spotify Integration, waited 5 mins, 1 hour, 24 hours, still only shows an outdated list of Playlists. Any thoughts? AFAIK everything is up to date. I’m aware Spotify changed their API, but not sure if that’s related.
Thanks!
@disuye
If you’re still having issues with the Spotify integration …
I have developed a SpotifyPlus Card Home Assistant custom component dashboard that adds extended support for Spotify premium account users.
This card utilizes services and features unique to the SpotifyPlus custom integration.
Note - this card will NOT work with the built-in HA Spotify integration; the SpotifyPlus custom integration is required.
Features
  • Spotify Media player interface with customizable controls and information display.
  • Search Spotify catalog for all media types (tracks, playlists, albums, artists, shows, audiobooks, episodes, categories, etc).
  • Display / Select your Spotify favorites: playlists, albums, artists, audiobooks, episodes, shows, tracks.
  • Display / Select Spotify Connect device outputs.
  • User-defined media item presets (both file and code edited supported).
  • User-defined recommendation presets; play dynamically generated content based on user-defined criteria (e.g. energy, loudness, danceability, etc).
  • Favorite status / add / remove support for all media types.
  • View Player Queue information.
  • Card Configuration Editor User-Interface for changing options.
Requirements
Limitations
  • Limited control of Google Chromecast devices. Chromecast devices are currently not fully supported by the SpotifyPlus integration. You can perform player functions (e.g. pause, resume, next track, etc) if the device is the currently active player, but you can’t wake up a device or initiate play of tracks / context.
Getting Started
  • make sure all requirements above have been installed.
  • follow the SpotifyPlus Card Installation Instructions to install the card.
  • refer to the Card Picker topic for how to add the card to a dashboard; that document also covers the various card configuration options.
More Information
Check out the following links for more information:
So it seems there is/was a maximum number of playlists which could be displayed in the Spotify Integration UI? In my cased 37. I deleted a few old 'lists (in the Spotify app) then the newer Playlists are shown at the top of the HA Spotify UI.
This limit doesn’t seem to apply to Tracks, Artists, Recently Played etc. etc… only the Playlist section.
Anyhow, fixed enough for me to move on :slight_smile:
Thanks for the recommendation, will take a look.
