Spotify integration, playlist missing
I’m using the Spotify integration, but only a few of the playlists I have created are available to play via the “browse media” section, I cannot figure out how to expose the other playlists.
I would Greatly appreciated any help
If you’re interested in Spotify, check out the SpotifyPlus Integration; it can do everything that the HA Spotify integration can do, and it supports both Sonos and Google Chromecast devices. You can also use the same Spotify developer account Client ID / Secret that you created for the HA Spotify integration if you want.
There is also a SpotifyPlus Card user-interface that contains a media player, and allows you to manage your Spotify favorites as well as search the Spotify catalog. You have to install the SpotifyPlus integration first though, and get it configured before you can use the SpotifyPlus Card.
Hope it helps!
Thanks for this, I’d need it to work via an Amazon Alexa though unfortunately :smirk:
@mada15
Apologies … my original response should have been "it supports all devices that implement the Spotify Connect protocol, including Sonos and Google Chromecast.
It should work if Amazon Alexa supports the Spotify Connect protocol, though I have not tested it with Alexa devices since I don’t own any of them. If your devices show up as sources in the Spotify integration source list, then they should be supported.
Ah! Fantastic, I will give it a go then! Thanks
For me it’s only the playlists that were created by Spotify themselves that do not show in HA. Playlists created by others do get added.
