Greetings,
I’ve seen the other post following the new Spotify integration regarding the INVALID_CLIENT error.
But I have a slightly different issue:
My Setup:
- Home Assistant in Docker (HTTP only)
- Nginx handling the subdomain
https://hassio.[mydomain]/
and enforcing SSL. (Standart 443 port)
So my home assistant is reachable athttps://hassio.domain/
But the Spotify Integration creates a link
https://accounts.spotify.com/authorize?response_type=code&client_id=[id]&redirect_uri=http://[some-ip]/auth/external/callback&state=[…]&scope=user-modify-playback-state,user-read-playback-state,user-read-private
This [some-ip] is no IP I know, especially neither the public nor local IP address of the home assistant server. Even if so, it won’t work, as Nginx doesn’t redirect access to the IP without hostname to the hassio subdomain. And as you note, it is also, not SSL.
I would expect https://hassio.[mydomain]/auth/external/callback...
(which I added to the Spotify Developer settings)
If I manually change the link it won’t work either with following error in the home assistant log:
2020-06-03 19:51:05 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 73, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 125, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 376, in get
flow_id=state["flow_id"], user_input=request.query["code"]
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 153, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 201, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 248, in async_step_creation
token = await self.flow_impl.async_resolve_external_data(self.external_data)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 142, in async_resolve_external_data
"redirect_uri": self.redirect_uri,
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 167, in _token_request
resp.raise_for_status()
File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 946, in raise_for_status
headers=self.headers)
aiohttp.client_exceptions.ClientResponseError: 400, message='Bad Request', url='https://accounts.spotify.com/api/token
Does someone have an idea on this?
