this solve the problem, thanks
Hello everyone,
Its possible to hide this area?
Off course:
type: custom:spotify-card
card_mod:
style: |
#footer {
display: none !important;
hide_warning: false
hide_top_header: true
hide_currently_playing: true
hide_playback_controls: true
hide_chromecast_devices: false
hide_connect_devices: true
display_style: grid
limit: 8
grid_covers_per_row: 4
playlist_type: discover-weekly
always_play_random_song: true
Thanks. for the solution
Hey, I’m using the card for quite some time now. I really love and use it a lot.
My only frustration is that my own playlist don’t show up in lovelace (those created by spotify, like "Release Radar, Discover Weekly, …) are displayed correctly however.
Does anyone have a solution for this?
Thanks,
J
hide: null
limit: 10
include_playlists:
- .*Spot
- .*ELE
- .*Juh
- .*Disco
- .*Your
- .*Rel
spotify_entity: media_player.spotify_117408964
filter_devices: null
playlist_type: default
account: default
grid_show_title: true
grid_covers_per_row: '5'
display_style: list
Good point. I hadn’t noticed but I’m seeing this same behavior. It seems like anything created by Spotify is not included in the list. That includes public playlists created by Spotify, and also the themed ones that say “… picked just for you”.
I was also having the problem others mentioned where the playlists won’t load at all. I was curious why just re-creating the card would fix it, so I pulled apart my definition one line at a time until it worked. What I found is that if I have a "limit: " value greater than 18 it will fail to load (not sure if that’s a fixed limit or something related to the number of playlists I have available in my account).
I installed this today.
I cant get it to work, it just says "error the spotify integration must be installed for this component to work… but it is installed and works with all other things
anyone got any tips for me
thanks
I got this installed, but I don’t like the device selection, it does not work good on touch or mouse input.
Is it possible to replicate the behaviour, I can hide the selection with CSS. But is it possible to create separate buttons for each device in my network?
Where I can select a device with the button I created and then press a playlist to launch it?
Or is this not possible?
Workaround:
Restating:
Awesome card. Now able to make a room level card. There is a bit of a delay when the album graphics load. Is there a way to speed this up such as cache or something similar? No way a deal breaker, but very noticeable delay. Maybe there are some best practice performance tweaks ? Thanks
What do you use as the underlying integration to Spotify?
I switched from the regular Spotify integration to the SpotifyPlus integration and the display of album art in the card went from 3 - 5+ seconds to almost instant.
The SpotifyPlus integration uses the spotifywebapiPython package - I wrote it as well. It makes calls directly to the Spotify Web API.
I believe the HA Spotify integration uses the spotipy python package, but not sure - it’s been awhile since I looked at it.
I have also started a beta test of my new SpotifyPlus Card UI, if you’re interested. It requires the SpotifyPlus integration. Check out the link for more info.
I’ve been trying to integrate Spotify into my dashboard for a few weeks now. My idea is to have a few buttons that create and play playlists by mood. It works quite well so far and looks like this:
But the playlist creation service works very unreliably for me (other Spotify Plus integration) - or crashes my server. I have seen that this integration can also create playlists, but without songs. Can I also use the services to create a dynamic playlist with a few parameters such as “energy” and create some kind of jukebox with it? I’m a bit confused by the many options.
Also if someone needs the yaml for that Spotify playlist card just ask, i think the layout works quite well for a playlist selection card.
with SpotifyPlus, you can create an empty playlist:
service: spotifyplus.playlist_create
entity_id: media_player.spotifyplus_john_s
name: My New Playlist
description: A Playlist created by the SpotifyPlus integration
public: false
collaborative: false
You would then need to add items to the playlist - there is no way to “auto populate” the playlist with a genre / vibe / popularity / etc. Here’s how to add items:
service: spotifyplus.playlist_items_add
playlist_id: 4yptcTKnXjCu3V92tVVafS <- the ID from the playlist_create call
uris: spotify:track:0NL83oUQmHLErXLOuvhgNX
Note that the uris
parameter can specify up to 100 track uri values (comma separated).
There is an API call available in the spotifywebapiPython (would need to be added to SpotifyPlus service list) that can be used to get track information based on genre (among other things) called GetTrackRecommendations.
One could (in theory) call the GetTrackRecommendations to return the list of tracks based on a genre / popularity / energy level, etc), create a dynamic playlist, and the add the found tracks to the playlist.
Here’s a Python example (from the help docs link above) that retrieves tracks with a genres of rock,hard-rock,rock-n-roll
, minLoudness=-9.201, minTimeSignature=4, and minEnergy=0.975
from spotifywebapipython import *
from spotifywebapipython.models import *
try:
CLIENT_ID:str = 'your_client_id'
CLIENT_SECRET:str = 'your_client_secret'
# create new spotify client instance.
spotify:SpotifyClient = SpotifyClient()
# generate a spotify client credentials access token (no scope, public data use only).
spotify.SetAuthTokenClientCredentials(CLIENT_ID, CLIENT_SECRET)
print('\nAuth Token:\n Type="%s"\n Scope="%s"' % (spotify.AuthToken.AuthorizationType, str(spotify.AuthToken.Scope)))
print('\nUser:\n DisplayName="%s"\n EMail="%s"' % (spotify.UserProfile.DisplayName, spotify.UserProfile.EMail))
# get Spotify track recommendations for specified criteria.
print('\nGetting track recommendations - I wanna rock!\n')
recommendations:TrackRecommendations = spotify.GetTrackRecommendations(seedGenres='rock,hard-rock,rock-n-roll',minLoudness=-9.201,minTimeSignature=4,minEnergy=0.975)
print(str(recommendations))
print('')
seed:RecommendationSeed
for seed in recommendations.Seeds:
print(str(seed))
print('')
print('Recommended Tracks:')
track:Track
for track in recommendations.Tracks:
print('- "{name}" ({uri})'.format(name=track.Name, uri=track.Uri))
#print(str(track))
except Exception as ex:
print("** Exception: %s" % str(ex))
Alright, nice. This sounds like it could theoretically work with a combination of a few service calls. Thank you very much for taking the time to write this up.
@shpongledsummer
I am in the process of adding the get_track_recommendations
to the SpotifyPlus integration. Will keep you posted.
@shpongledsummer
I implemented the get_track_recommendations
service with SpotifyPlus integration v1.0.62 …
[ 1.0.62 ] - 2024/10/27
- Added service
to get track recommendations for specified criteria. - Added the following extra state attribute:
sp_track_is_explicit
- denotes the nowplaying track contains explicit lyrics (true) or not (false).
SpotifyPlus Service Documentation is on the wiki. The service supports all of the parameters implemented by the Spotify Web API Get Track Recommendations endpoint.
Here’s a couple of service call examples:
Example YAML
I wanna rock! example …
service: spotifyplus.get_track_recommendations
limit_total: 50
seed_genres: "rock,hard-rock,rock-n-roll"
min_loudness: -9.201
min_time_signature: 4
min_energy: 0.975
I wanna wind down example - artist George Winston (e.g. 3jdODvx7rIdq0UGU7BOVR3) …
limit_total: 50
seed_artists: "3jdODvx7rIdq0UGU7BOVR3"
seed_genres: "piano"
min_energy: 0.175
really cool, thanks for adding this!
@shpongledsummer
I finally released the SpotifyPlus Card Dashboard that contains a feature you might like relating to the Track Recommendations that we discussed a couple of weeks ago.
The dashboard allows you to define a user-preset that contains recommendation criteria used to search Spotify for matching tracks. It then calls the GetTrackRecommendations endpoint to get the matching tracks, builds a play queue of the tracks, and starts playing.
The configuration supports all of the 45 different criteria for the get_track_recommendations
service.
Feel free to check it out when you get some time. Here are some example screenshots and yaml configurations for presets that I have played with so far.
SpotifyPlus Card Configuration - userPresets
userPresets:
- name: I Wanna Rock!
subtitle: Recommended
image_url: https://t.scdn.co/images/728ed47fc1674feb95f7ac20236eb6d7.jpeg
type: recommendations
recommendations:
seed_genres: rock,hard-rock,rock-n-roll
min_energy: 0.975
- name: Wind Down Piano
recommendations:
seed_artists: 3jdODvx7rIdq0UGU7BOVR3
seed_genres: piano
min_energy: 0.175
- name: Wind Down Guitar
recommendations:
seed_genres: guitar
max_acousticness: 0.15
max_energy: 0.175
- name: Wind Down Country
recommendations:
seed_genres: country
max_speechiness: 0.225
max_energy: 0.325
SpotifyPlus Card User Preset Browser
Generated Play Queue for the “I Wanna Rock!” preset
oh wow, this sounds great! I guess I have something to tinker with this weekend
