Spotify Lovelace Card
I still don’t get the Grid option working… Using yaml mode I always have the default style…
EDIT: After the latest release of the card i finally get it working… very nice style.
But after latest spotcast release i don’t see anymore the cast devices between the list of the players…
I get this in the console:
EDIT2: Did you disabled featuredplaylist option? Or how did you changed this option together with country_code?
I have had some issues with releasing. Try the latest with
playlist_type: featured
Yes, it works… And what about cast devices?
You need spotcast for that. Is it not working?
Yes, i have it installed as latest release… i posted the same question also in the spotcast thread…
I can see in the list only the alexa devices and no cast like before!
The spotcast.start service is working but cannot see any cast device into the list created by the spotify-card
Thank you for replying, I will research it on their site, hopefully I can find something on it.
Someone else also has that problem. Please open a ticket in the repo with logs
Upgrade first to 3.3.3 for spotcast and include the logs with lines containing websocket_handle_castdevices
I installed 3.3.3 but the logs say nothing about websocket_handle_devices. The console of Chrome says the same i already posted here. Do maybe i need to add something to the HA logger about the component?
Schermata 2020-07-17 alle 19.48.34
Install 3.3.4, 99% certain it fixes things
I saw that 0.112 had a different way to store cast devices
Now it is solved with spotcast 3.3.4
I can confirm it now works. Thanks for your effort Niklas
Something strange happened today… just after installing beta 15 i loose the configuration about the new UI style (i mean grid, featured playlists etc…) and i was asked again to authenticate. I downgraded to beta 14 an all was ok again. More, in HACS, clicking on the repository i was addressed to the old repository and not to the new. What happened?
I might have done something wrong with .15. Use .14 until I can fix it later today
New release out which simplifies the grid settings.
Is it possible to remove the ‘choose player’ menu and have a default player selected?
I notice on the GitHub it says to use " device: <optional name of a device to pre-select>"
I have tried using the entity id and friendly name but neither seems to work
In v1 it is. V2 hasnt gotten that feature yet.
I’ll add that in a day or so.
spotify
Great! Thank you!
I’ve released v2 beta19 which has this option. Configure in GUI or add
default_device: "Default device"
Hi all!
I was using the “old” version of this card. Now, i try the new but it seems to not work:
type: 'custom:spotify-card'
client_id: xxxx
What am i doing wrong ? ( i don’t need spotcast)
Hi, I’m having a similar issue. When I add the Card, it wants the Spotify Integration to be installed, but it is installed and working, as you can see below:
It’s a known issue, issue is posted on GitHub, he is working on it
