ok sorry for the post
It should be solved
V2 requires spotcast for many other things than chromcast.
Version 2 is now released out of beta. Thanks to everyone helping testing it.
updated and still not working for me:
also tried removing spotify integration and re-adding it, same result
e: nevermind, it works. I just configured spotcast wrong, sorry!
Ok now it’s working, great job!!
Would like to share what you did to solve it? It may be helpful to others with the same problem. Cheers.
I just followed the configuration manual of spotcast:
I mistankenly entered my spotify_client and spotify_secret information for sp_dc and sp_key instead of the cookies.
Thanks!
That’s not my issue than.
I’m able to load Featured playlist and Discover Weekly playlist but my default playlist won’t load.
great release!!
Hi.
I have a problem since update 0.113.
“Spotcast integration has to be installed for this component to work”
I don’t see a spotcast on HACS, and if I try to add the repository, HACS tells me it already exists. Could someone help me? Thank you.
Spotify integration is ok. But I don’t find Spotcast integration in HACS or Settings / Integration.
Sorry for misinformation. It is in hacs -> integrations but it is not named spotcast.
Click the ‘+’ icon in the bottom right and do a search.
It says ‘start spotify on chromecast’ so look for keyword ‘spotify’ or ‘chromecast’ maybe?
Thanks. I only have “Spotify Lovelace Card”
It’s this one. But you can find it in HACS. Maybe you already installed it. Try adding your data in your configuration.yaml
I am on version 2.0 and have the spotcast addon installed, but still shows an error that Spotify integration needs to be installed, which it is
I have the same issue…
- type: 'custom:spotify-card'
device: Sonos Alrum
default_device: media_player.alrum
custom_fields:
icon: *icon_sonos
style:
top: 50%
left: 50%
width: 100%
template: media
Hi
Could you share your general config of the card and the .js file, if you did something there?
Your spotify media player needs either to be named something starting in spotify or you need to configure the entity id of the media_player.spotify this is easistest done using the gui configurator for the card under advanced
