Spotify Lovelace Card
Is it also possible with this card, to make shortcuts to radiochannels, and cast it the same way to cast/sonos devices?
Would love that :stuck_out_tongue:
I’m actually looking for a solution which can:
  • start/stop spotify playlists on any device like sonos, google home… (think this card can)
  • start/stop shortcuts which we can add, containing radio channels (not sure this card can)
  • show the cover/artist/name song currently playing
Been looking for ages for all possible things, but it seems theres no such thing yet?
This card with spotcast is the closest i think, although i wanted that with the mini media player…
I know i ask a lot
States are working good so far, thanks for the quick response @fondberg and @FL550 !
No this is not possible with this card. This card can only start Spotify on Spotify Connect devices and Chromecast devices.
I also think your requested features are too much for a single card. It’s better to split this up to multiple cards.
For the playback information I can recommend mini-media-player, but as far as I know it is not possible to start radio channels on Spotify Connect Devices. For Chromecast devices this is not impossible, but I don’t know about an integration for HA.
For radio, if there is a URI that works with the Spotify API you can add a button which runs a script that calls spotcast to start it.
Sonos has their own api so this is not supported though
yes i have an url that works, so that would be cool, however if its not working with sonos, than that is a no go either
Crap :frowning: i want to much
Its not possible to add to the card the possibility to add shortcuts?
Like in mini media player…?
That way we can add radio to use spotcast to cast to google, and a shortcut to play to sonos…
I looked for a radio/tunein integration which does the same like your card does with spotify, but it doesnt exist either
I think shortcuts is a bit overkill for this card I’m afraid. Regarding Sonos, they use a different API but if you know how to control Sonos and Spotify using HA it could be interesting to see if it can be added
Thanks, just installed - works great!
Since a few days, I always have the yellow bar : spotify integration needs to be installed… It goes away after 10 sec…before it went away after like 1-2 sec
I have the same. Is there a cause for this or a solution?
We restructured the update methods to reduce the amount of the rendering calls and to decrease loading time. Maybe this introduced the slow update of the spotify integration check. I’ll have a look into this later this day.
I was looking for answers but unfortunately I did not find. What should I enter in the settings to show my playlists and additionally discover-weekly ?
I’ve released a temporary fix which hides this warning as the error is only in the UI. Playback state information is working normal.
We will investigate further on this issue.
If you are not using the grafical editor (which I recommend), you can have a look here: https://github.com/custom-cards/spotify-card#yaml-mode
I’m using a graphical editor, but when I set “discover-weekly”, I don’t have the option to add my playlists (playlists created by me). Or I don’t know how to do it
That is the correct behaviour. You can’t show both in the same card. If you want your own playlists and some from discover weekly, leave it on default. Then add the playlist from discover weekly to your playlists directly on Spotify.
OK thanks for fast answer !
Hi, I’m trying to setup the plugin, however I’m having trouble setting up spotcast.
The problem is dat i can’t find the SP_KEY in my cookies. SP_DC is present.
Anyone else having that problem?
Try following the guide exactly and it will work -> https://github.com/fondberg/spotcast
You’re right, I was using the chromium based edge (you can even paste the chrome url in there to get you to the cookie page). However in Edge I didn’t have the SP_KEY. Installed Chrome and there it was.
Hi All!
I successfully integrated this card and works very well from the point of view of music control.
However, the grid visualisation seems to be faulty on Safari (v. 13.1.2). Anybody experiencing the same issue and with nay workaround?
