Hi Chris. Interested in your take. I have a Sonos ecosystem and love the look of the spotify-card.
Looking for a way to intercept when you click a playlist, and to pass that along to a script or a service-call, as it is possible as you say to start up a Spotify Playlist on Sonos speakers.
my Spotify Lovelace Card turned to gray scale and i’m not able to control anything. When i press any button from the playlists i get an error message "Failed to call service spotcast/start. string value is None for dictionary value @ data[‘spotify_device_id’].
I checked my spotify account settings in my configuration file, my spotcast settings also i see “No devices found” , but when i play something in any of my deivces i see the song title and the device where spotify is active.
I’ve actually come up with some code (heavily inspired by this card), which fetches the playlists from SpotCast and can cast to a configurable player, e.g. a sonos player. I have the proof of concept up on GitHub, in case you’re interested https://github.com/ChrisK91/sonos-playlist-card
I’m working on getting a current playing indicator as well, but I’m quite busy at the moment. It can however display a grid and should be customizable with the custom card css. I’ll try to add some more functionality the coming days. My javascript is quite rusty…
Is featured and discover-weekly and the default the only playlist we can chose?
Is it possible to add:
albums
categories (this wuld rock ,all the categories)
Why i ask?
Well i would like to use the media browser function , but i cant select the output there.
What i’m trying to achieve (i went away from sonos to only cast devices):
A popup card showing a library , where i can chose from albums/ playlists/ categories
Chose an album or playlist and play it on the device i select…
See my post (#721) and related screenshot: I used picture cards to list some of my playlist or album in a specific HA view. When you click an album cover, it plays. I don’t know if useful
I’ve been using spotcast and this card for the last year and I love it.
My only problem is that I always have to go to integration → Spotify and reload the integration to make it fully work, otherwise I’m only able to launch the first saved playlist in my card but can’t control anything else.
After I reload the integration I can fully use the card again, but only last for a bit.
I tried searching in this thread but couldn’t find a similar problem to mine.
Does anyone know what it can be?
I don’t know whether to post this here or in the Spotcast thread. However, I installed the Spotify integration and the Spotcast one. I even upgraded my Spotify to premium. Still I get this error when loading the component. I know spotcast is in fact installed correctly as I have the spotcast chromecast sensor and spotcast.start available under developer tools → services and it works. I’m all out of ideas. I have reinstallede the Spotify Integration, Spotcast and this component several times. any idea what to do?
I’ve got the same problem as AnneEjsing. I had already spotify premium.
The only failure was that I’ve installed first “custom-cards/spotify-card” and then the “Spotify Integration”. I 've already tried reinstalling “custom-cards/spotify-card” → no success!
Any idea?
EDIT:
Sorry my failure! I can’ read. I forgot to install “Spotcast”.
