Using Hassio and now having a Google Home Mini that i would like to play a certain Spotify playlist as wake-up alarm.
Is there anyone that have a working config already?
I have tested this without success.
So what am i doing wrong?
script:
morning_music:
sequence:
- service: media_player.volume_set
entity_id: media_player.googlehome6157
volume_level: 0.50
- service: media_player.play_media
entity_id: media_player.spotify
media_content_id: spotify:user:dawnlord:playlist:6YrwtfevNdgc44vI2HiO5j
media_content_type: playlist
automations:
- alias: 'test'
initial_state: true
- platform: time
at: '17:45:00'
service: script.turn_on
entity_id: script.morning_music
This works when i already have the mini fired up.
But in the morning when i havent played anything yet script doesnt start.
morning_music:
sequence:
- service: media_player.select_source
data_template:
source: media_player.googlehome6157
data_template:
media_content_id: spotify:user:spotify:playlist:37i9dQZF1DX2MyUCsl25eb
Have you tried the turn_on command?
Something like this at the top of the sequence maybe?
- service: media_player.turn_on
When i tried that there was a blipping sound but nothing more
Since i have several mini’s i have created a tts-script that engages the spotifylist.
That sorted out my problem
play_spotify_list:
sequence:
volume_level: 0.50
- service: tts.google_say
data_template:
message: >
Hey Google. Play Spotify playlist {{states.input_select.spotifylist.state}} on {{states.input_select.speakers.state}}.
I have been trying to get this working on my system, in my automations.yaml I have added:
alias: 'test'
initial_state: true
- platform: time
at: '22:45:00'
and in the scripts.yaml I have entered:
play_spotify_list:
sequence:
entity_id: media_player.googlehome2409
volume_level: 0.20
data_template:
message: >
Hey Google. Play hot hits australia on study speaker
Unfortunately running the script manually does nothing, am I missing something?
Did you ever figure out how to do this without the work-around with TTS? Also, does the TTS actually announce the “Hey Google” part out loud?
Also haven’t been successful in getting this to work.
Yes it announces it all out loud, it works but not a good solution for me.
I have still been unable to get it going, did you have any joy?
No no luck yet
You can do this via Logitech Media Server. It has a castbridge to connect to all devices with google cast and you can expose any chromecast device (or group) as a Spotify connect client. However, i do not recommend doing this on a rpi… in my tests it was not able to handle the transcoding well.
ok I understood that there is no way to control spotify with Home Assistan even if they claim that you can do it
current implementation for spotify needs a running client and it is not even able to start spotify on a satellite like Google Home or Echo.
So we need to say that HA has no support for Spotify yet.
Hi guys,
I will able to do that with spotcast component. Its works fine even with idle cast devices.
