Spotify redirecting to wrong internal address
Hopefully this is the right board for this. I set up the Spotify integration the other day, but it keeps redirecting to the wrong address. In Spotify’s dashboard I have the redirt URI set to http://192.168.0.24:8123/auth/external/callback, but when I try to set it up it instead is trying to connect to .11, which is another instance of HA running. I have two because one is stable and I’m in the process of setting up another on a different device and making sure all of the new things I want to add are possible before I make the switch. I can’t imagine that it’s somehow seeing the other instance that’s running if Spotify itself is told to direct to .24.
I only added the integration in my config for .24, I have not touched .11 in some time. I’ve also tried editing the url that comes up in the new window to just point it to the right address, but that didn’t work either.
Have you tried to add internal_url in the config?
I have not. Would that just be internal_url: 192.168.0.24 ?
Check out the docs at Basic where you would add http://192.168.0.24:8123 as internal_url.
That gave me the right address in the bar, but I still get
INVALID_CLIENT: Invalid redirect URI
