Is there a way to expose the states of the Sprinkler Controller to HA?
I see that in sprinkler.h there are states declared but I don’t know how to call it.
enum SprinklerState : uint8_t {
// NOTE: these states are used by both SprinklerValveOperator and Sprinkler (the controller)!
IDLE, // system/valve is off
STARTING, // system/valve is starting/"half open" -- either pump or valve is on, but the remaining pump/valve is not
ACTIVE, // system/valve is running its cycle
STOPPING, // system/valve is stopping/"half open" -- either pump or valve is on, but the remaining pump/valve is not
BYPASS // used by SprinklerValveOperator to ignore the instance checking pump status
