I have been working on setting up a 8 zone sprinkler controller with an nextion display. Currently I have working touch buttons that change colour if a zone is running, you cannot run more than one zone at one time. Home-assistant can turn on/off each zone and the display reflects the running zone.
What I would like to have some sort of per predefined zone auto off with a countdown timer displayed. I am not sure if this is possible. Does anyone have any ideas?
Here is my current code for anyone interested:-
For each button on the nextion you need to have the below in either the ‘Touch Press Event’ or ‘Touch Release Event’ to pass back to esphome button press events
As detailed here https://github.com/esphome/issues/issues/83
if(bt0.val==1)
printh 65 00 02 01 FF FF FF
}else
printh 65 00 02 00 FF FF FF
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "here"
password: "that"
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.178.100
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.178.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
dns1: 192.168.178.2
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
port: 80
uart:
rx_pin: D7
tx_pin: D5
baud_rate: 9600
time:
- platform: sntp
timezone: Australia/Melbourne
display:
- platform: nextion
update_interval: 10s
lambda: |-
char time[10];
time_t currTime = id(sntp_time).now().timestamp;
strftime(time, sizeof(time), "%I:%M %p", localtime(&currTime));
it.set_component_text("time", time);
i2c:
sda: 4
scl: 5
scan: False
pcf8574:
- id: 'pcf8574_hub'
address: 0x20
pcf8575: False
binary_sensor:
- platform: nextion
page_id: 0
component_id: 2
nextion_id: nextion_display
on_state:
if:
condition:
- binary_sensor.is_on: zone1_button
then:
- switch.turn_on: relay1
else:
- switch.turn_off: relay1
- platform: nextion
page_id: 0
component_id: 4
on_state:
if:
condition:
- binary_sensor.is_on: zone2_button
then:
- switch.turn_on: relay2
else:
- switch.turn_off: relay2
- platform: nextion
page_id: 0
component_id: 5
on_state:
if:
condition:
- binary_sensor.is_on: zone3_button
then:
- switch.turn_on: relay3
else:
- switch.turn_off: relay3
- platform: nextion
page_id: 0
component_id: 6
on_state:
if:
condition:
- binary_sensor.is_on: zone4_button
then:
- switch.turn_on: relay4
else:
- switch.turn_off: relay4
- platform: nextion
page_id: 0
component_id: 7
on_state:
if:
condition:
- binary_sensor.is_on: zone5_button
then:
- switch.turn_on: relay5
else:
- switch.turn_off: relay5
- platform: nextion
page_id: 0
component_id: 8
on_state:
if:
condition:
- binary_sensor.is_on: zone6_button
then:
- switch.turn_on: relay6
else:
- switch.turn_off: relay6
- platform: nextion
page_id: 0
component_id: 9
on_state:
if:
condition:
- binary_sensor.is_on: zone7_button
then:
- switch.turn_on: relay7
else:
- switch.turn_off: relay7
- platform: nextion
page_id: 0
component_id: 10
on_state:
if:
condition:
- binary_sensor.is_on: zone8_button
then:
- switch.turn_on: relay8
else:
- switch.turn_off: relay8
switch:
- platform: gpio
restore_mode: ALWAYS_OFF
interlock: [relay2 ,relay3, relay4, relay5, relay6, relay7, relay8]
pin:
pcf8574: pcf8574_hub
number: 0
mode: OUTPUT
inverted: True
on_turn_on:
then:
- lambda: |-
id(nextion_display).set_component_value("bt0", 1);
- logger.log: "Send enable to touch button bt0"
on_turn_off:
- lambda: |-
id(nextion_display).set_component_value("bt0", 0);
- logger.log: "Send disable to touch button bt0"
- platform: gpio
interlock: [relay1 ,relay3, relay4, relay5, relay6, relay7, relay8]
pin:
number: 1
mode: OUTPUT
inverted: True
on_turn_on:
then:
- lambda: |-
id(nextion_display).set_component_value("bt1", 1);
- logger.log: "Send enable to touch button bt1"
on_turn_off:
- lambda: |-
id(nextion_display).set_component_value("bt1", 0);
- logger.log: "Send disable to touch button bt1"
- platform: gpio
interlock: [relay1 ,relay2, relay4, relay5, relay6, relay7, relay8]
pin:
number: 2
mode: OUTPUT
inverted: True
on_turn_on:
then:
- lambda: |-
id(nextion_display).set_component_value("bt2", 1);
- logger.log: "Send enable to touch button bt2"
on_turn_off:
- lambda: |-
id(nextion_display).set_component_value("bt2", 0);
- logger.log: "Send disable to touch button bt2"
- platform: gpio
interlock: [relay1 ,relay2, relay3, relay5, relay6, relay7, relay8]
pin:
number: 3
mode: OUTPUT
inverted: True
on_turn_on:
then:
- lambda: |-
id(nextion_display).set_component_value("bt3", 1);
- logger.log: "Send enable to touch button bt3"
on_turn_off:
- lambda: |-
id(nextion_display).set_component_value("bt3", 0);
- logger.log: "Send disable to touch button bt3"
- platform: gpio
interlock: [relay1 ,relay2, relay3, relay4, relay6, relay7, relay8]
pin:
number: 4
mode: OUTPUT
inverted: True
on_turn_on:
then:
- lambda: |-
id(nextion_display).set_component_value("bt4", 1);
- logger.log: "Send enable to touch button bt4"
on_turn_off:
- lambda: |-
id(nextion_display).set_component_value("bt4", 0);
- logger.log: "Send disable to touch button bt4"
- platform: gpio
interlock: [relay1, relay2 ,relay3, relay4, relay5, relay7, relay8]
pin:
number: 5
mode: OUTPUT
inverted: True
on_turn_on:
then:
- lambda: |-
id(nextion_display).set_component_value("bt5", 1);
- logger.log: "Send enable to touch button bt5"
on_turn_off:
- lambda: |-
id(nextion_display).set_component_value("bt5", 0);
- logger.log: "Send disable to touch button bt5"
- platform: gpio
interlock: [relay1, relay2 ,relay3, relay4, relay5, relay6, relay8]
pin:
number: 6
mode: OUTPUT
inverted: True
on_turn_on:
then:
- lambda: |-
id(nextion_display).set_component_value("bt6", 1);
- logger.log: "Send enable to touch button bt6"
on_turn_off:
- lambda: |-
id(nextion_display).set_component_value("bt6", 0);
- logger.log: "Send disable to touch button bt6"
- platform: gpio
interlock: [relay1, relay2 ,relay3, relay4, relay5, relay6, relay7]
pin:
number: 7
mode: OUTPUT
inverted: True
on_turn_on:
then:
- lambda: |-
id(nextion_display).set_component_value("bt7", 1);
- logger.log: "Send enable to touch button bt7"
on_turn_off:
- lambda: |-
id(nextion_display).set_component_value("bt7", 0);
- logger.log: "Send disable to touch button bt7"
- platform: wifi_signal
update_interval: 60s
- platform: uptime
