I have a sql sensor, works fine.
But how do I make it get yesterday at 23 instead
datetime(yesterday 23:00:00')
- platform: sql
queries:
- name: Kl_23
query: "SELECT * FROM states WHERE entity_id = 'sensor.energi_data_service' AND last_updated <= datetime('2022-11-27 23:00:00') ORDER BY last_updated DESC LIMIT 1;"
column: 'state'
This takes the current date (not time) and subtracts 1 day, then adds 23 hours to get 23:00 last night. You might also want to check whether you should be using local time or UTC. My hassos uses UTC (not sure if it’s always UTC or using system config), so I would use UTC_DATE() instead of CURDATE().
