Hi All
Is it possible to use a Stored Procedure in the SQL Integration? IOW instead of
query: 'SELECT .....'
do
query: 'call <stored Procedure name>'
Hi All
do
Seems easy enough to test yourself?
I did, but it does not seem to work - It does not create an Entity when I do it - maybe there is another way of doing it?
What does your log say?
Which DB backend are you using?
I do not see anything in the Log. I’m using an external mySQL DB.
OK - So when I change the “Select Query*” line to call , I get this error. Very limited
So now my question is: Is there a way around this?
