SQL to get historic attribute data from MariaDB
I’m using MariaDB and install phpDBAdmin to get hostoric data from a sensor (fritz call montor). So I want to show the last calls with details of the day but if I add curdate to WHERE I did not get any data:
SELECT state FROM states WHERE entity_id = ’ sensor.fritz_box_7590_call_monitor_privat’ AND last_updated >= CURDATE() ORDER BY last_updated DESC
Whats the problem and how can I create a Wherer with dat_time?
Thanks, Steffen
Looking at the data in my database, last_updated is UTC, so you would have to use the following:
last_updated >= utc_date()
Great thank you, UTC is the key I did not find.
