Hi All,
I’m trying to use a bit of SQL to grab the cost of electricity over the last 5 days which is stored as an entity, but overwritten on a daily basis.
I’ve got the following SQL - but I’m getting an invalid sql statement error when trying to run it using the home assistant SQL integration - if it helps, I’m expecting a numerical value - any ideas?
SELECT *
FROM
states
WHERE
entity_id = 'sensor.electricity_previous_accumulative_cost'
ORDER BY ABS(strftime('%s', created) - strftime('%s', datetime('now'), '-1 day'))
LIMIT
1;
Original SQL code taken from this thread - Show sensor value from 24 hours previous
I’m using the built-in HA Database if it helps.
Leacho
