Well you should have crossed them better…
It fell Over again
llback(frame_name, result)
File "/usr/local/lib/python3.14/site-packages/bellows/ezsp/__init__.py", line 593, in handle_callback
LOGGER.exception("Exception running handler", exc_info=e)
File "/usr/local/lib/python3.14/logging/__init__.py", line 1555, in exception
self.error(msg, *args, exc_info=exc_info, **kwargs)
File "/usr/local/lib/python3.14/logging/__init__.py", line 1549, in error
self._log(ERROR, msg, args, **kwargs)
File "/usr/local/lib/python3.14/logging/__init__.py", line 1663, in _log
record = self.makeRecord(self.name, level, fn, lno, msg, args,
exc_info, func, extra, sinfo)
File "/usr/local/lib/python3.14/logging/__init__.py", line 1632, in makeRecord
rv = _logRecordFactory(name, level, fn, lno, msg, args, exc_info, func,
sinfo)
File "/usr/local/lib/python3.14/logging/__init__.py", line 355, in __init__
self.threadName = threading.current_thread().name
File "/usr/local/lib/python3.14/threading.py", line 1143, in name
assert self._initialized, "Thread.__init__() not called"
None: Thread.__init__() not called
File "/usr/local/lib/python3.14/asyncio/events.py", line 94, in _run
self._context.run(self._callback, *self._args)
File "/usr/local/lib/python3.14/site-packages/bellows/thread.py", line 112, in check_result_wrapper
result = call()
File "/usr/local/lib/python3.14/site-packages/bellows/ezsp/__init__.py", line 375, in frame_received
LOGGER.warning("Failed to parse frame, ignoring")
File "/usr/local/lib/python3.14/logging/__init__.py", line 1532, in warning
self._log(WARNING, msg, args, **kwargs)
sinfo)
File "/usr/local/lib/python3.14/asyncio/base_events.py", line 1937, in call_exception_handler
ctx.run(self._exception_handler, self, context)
File "/usr/src/homeassistant/homeassistant/runner.py", line 239, in _async_loop_exception_handler
logger.error(
...<4 lines>...
sinfo)
File "/usr/local/lib/python3.14/asyncio/base_events.py", line 1946, in call_exception_handler
self.default_exception_handler({
...<3 lines>...
File "/usr/local/lib/python3.14/asyncio/base_events.py", line 1885, in default_exception_handler
logger.error('\n'.join(log_lines), exc_info=exc_info)
sinfo)
File "/usr/src/homeassistant/homeassistant/runner.py", line 290, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.14/asyncio/base_events.py", line 706, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.14/asyncio/base_events.py", line 677, in run_forever
self._run_once()
File "/usr/local/lib/python3.14/asyncio/base_events.py", line 2056, in _run_once
handle._run()
File "/usr/local/lib/python3.14/asyncio/events.py", line 138, in _run
return super()._run()
File "/usr/local/lib/python3.14/asyncio/events.py", line 109, in _run
self._loop.call_exception_handler(context)
File "/usr/local/lib/python3.14/asyncio/base_events.py", line 1956, in call_exception_handler
logger.error('Exception in default exception handler '
...<2 lines>...
exc_info=True)
sinfo)
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 341, in _async_dispatch_entity_id_event
hass.async_run_hass_job(job, event)
File "/usr/src/homeassistant/homeassistant/core.py", line 935, in async_run_hass_job
hassjob.target(*args)
File "/usr/src/homeassistant/homeassistant/components/utility_meter/sensor.py", line 500, in async_reading
_LOGGER.warning(
...<4 lines>...
sinfo)
File "/usr/src/homeassistant/homeassistant/core.py", line 1678, in _async_dispatch
self._hass.async_run_hass_job(job, event)
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 343, in _async_dispatch_entity_id_event
_LOGGER.exception(
...<3 lines>...
sinfo)
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 202, in async_update_listeners
update_callback()
File "/usr/src/homeassistant/homeassistant/components/shelly/entity.py", line 388, in _update_callback
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1061, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1294, in _async_write_ha_state
self.hass.states.async_set_internal(
...<7 lines>...
File "/usr/src/homeassistant/homeassistant/core.py", line 2531, in async_set_internal
self._bus.async_fire_internal(
...<4 lines>...
File "/usr/src/homeassistant/homeassistant/core.py", line 1635, in async_fire_internal
self._async_dispatch(event_type, event_data, origin, context, time_fired)
File "/usr/src/homeassistant/homeassistant/core.py", line 1680, in _async_dispatch
_LOGGER.exception("Error running job: %s", job)
sinfo)
File "/usr/local/lib/python3.14/asyncio/selector_events.py", line 1258, in _read_ready
self._protocol.datagram_received(data, addr)
File "/usr/local/lib/python3.14/site-packages/aioshelly/block_device/coap.py", line 220, in datagram_received
self.subscriptions[device_id](msg)
File "/usr/local/lib/python3.14/site-packages/aioshelly/block_device/device.py", line 223, in _coap_message_received
self._update_listener(self, BlockUpdateType.ONLINE)
File "/usr/src/homeassistant/homeassistant/components/shelly/coordinator.py", line 467, in _async_handle_update
self.async_set_updated_data(None)
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 620, in async_set_updated_data
self.async_update_listeners()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 204, in async_update_listeners
self.logger.exception(
...<3 lines>...
sinfo)
logger.error(
...<4 lines>...
sinfo)
...<3 lines>...
sinfo)
File "/usr/src/homeassistant/homeassistant/runner.py", line 293, in run
_cancel_all_tasks_with_timeout(loop, TASK_CANCELATION_TIMEOUT)
File "/usr/src/homeassistant/homeassistant/runner.py", line 312, in _cancel_all_tasks_with_timeout
loop.run_until_complete(asyncio.wait(to_cancel, timeout=timeout))
self.run_forever()
self._run_once()
handle._run()
...<2 lines>...
exc_info=True)
sinfo)
File "<frozen runpy>", line 203, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 227, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 213, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 298, in run
loop.close()
File "/usr/local/lib/python3.14/asyncio/unix_events.py", line 71, in close
super().close()
File "/usr/local/lib/python3.14/asyncio/selector_events.py", line 105, in close
super().close()
File "/usr/local/lib/python3.14/asyncio/base_events.py", line 750, in close
executor.shutdown(wait=False)
File "/usr/src/homeassistant/homeassistant/util/executor.py", line 76, in shutdown
self.join_threads_or_timeout()
File "/usr/src/homeassistant/homeassistant/util/executor.py", line 91, in join_threads_or_timeout
remaining_threads -= join_or_interrupt_threads(
...<3 lines>...
File "/usr/src/homeassistant/homeassistant/util/executor.py", line 43, in join_or_interrupt_threads
thread.join(timeout=timeout_per_thread)
File "/usr/local/lib/python3.14/threading.py", line 1124, in join
raise RuntimeError("cannot join thread before it is started")
None: cannot join thread before it is started
Exception ignored on threading shutdown:
File "/usr/src/homeassistant/homeassistant/util/thread.py", line 24, in deadlock_safe_shutdown
and thread.is_alive()
File "/usr/local/lib/python3.14/threading.py", line 1185, in is_alive
AssertionError: Thread.__init__() not called
Exception ignored in atexit callback <bound method finalize._exitfunc of <class 'weakref.finalize'>>:
File "/usr/local/lib/python3.14/weakref.py", line 568, in _exitfunc
sys.excepthook(*sys.exc_info())
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 631, in <lambda>
sys.excepthook = lambda *args: logging.getLogger().exception(
2026-08-20 11:28:33.868 ERROR (stream_worker) [root] Uncaught thread exception
File "/usr/local/lib/python3.14/threading.py", line 1082, in _bootstrap_inner
self._context.run(self.run)
File "/usr/local/lib/python3.14/threading.py", line 1024, in run
self._target(*self._args, **self._kwargs)
File "/usr/src/homeassistant/homeassistant/components/stream/__init__.py", line 482, in _run_worker
stream_worker(
...<6 lines>...
File "/usr/src/homeassistant/homeassistant/components/stream/worker.py", line 756, in stream_worker
muxer.mux_packet(packet)
File "/usr/src/homeassistant/homeassistant/components/stream/worker.py", line 304, in mux_packet
self.check_flush_part(packet)
File "/usr/src/homeassistant/homeassistant/components/stream/worker.py", line 343, in check_flush_part
self.flush(packet, last_part=False)
File "/usr/src/homeassistant/homeassistant/components/stream/worker.py", line 393, in flush
self._hass.loop.call_soon_threadsafe(
...<17 lines>...
File "/usr/local/lib/python3.14/asyncio/base_events.py", line 872, in call_soon_threadsafe
self._check_closed()
File "/usr/local/lib/python3.14/asyncio/base_events.py", line 550, in _check_closed
raise RuntimeError('Event loop is closed')
None: Event loop is closed
Exception ignored in atexit callback <function shutdown at 0x36af84ee290>:
File "/usr/local/lib/python3.14/logging/__init__.py", line 2246, in shutdown
h.close()
File "/usr/src/homeassistant/homeassistant/util/logging.py", line 124, in close
self.listener.stop()
File "/usr/local/lib/python3.14/logging/handlers.py", line 1644, in stop
self._thread.join()
RuntimeError: cannot join thread before it is started
[01:28:37] INFO: Home Assistant Core finish process exit code 1
[01:28:37] INFO: Home Assistant Core service shutdown
