I think You just answered your thoughts, There are a few very capable graph cards in HACS, And Many if not Most People are using the Native DB also ( For these cards )
So have MariaDB(which does support “grafana”
So it’s basically a matter of How big are your DB, and how big do you “want it / need it to be”, an external DB is also an option, it all come down to the amount of time you will put on maintenance etc.
With a solid Backup, i would say, go for the DB you find easiest to maintain
( The Internal Native DB, is maintained, and constantly optimized, So i honestly believe that’s you best choice, if you only have had Influx for Grafana .
I Previously had both Add-Ons, but skipped both when i found graph:cards that met my needs, and with all new enhancements in HA, you can basically “Trigger” upon what ever you want, with a template. , Grafana was a Pita, but awesome graphs, but some Custom:Cards have “overcome” that now
Along with VS Code, I think this may be be of the more memory hungry resource suckers on HomeAssistant, and may have contributed to your system crashing, possibly as it ran out of memory resources.
Historically Grafana was used for pretty graphs, however the changes to HomeAssistant over the last year or two have vastly improved the usability of the in-built graphs. Keeping two databases side by side seems a little inefficient in my opinion, and two different flavours more so. I would be surprised if Grafana cannot be tweaked to access and display the data from another database such as VictoriaMetrics instead of InfluxDB, version 1, 2, or 3/whatever.
InfluxDB: You didn’t need it - you won’t miss it. For those that did however, I commiserate deeply the rug pull was so swift, brutal and fatal. There will be workarounds, and the code will be revised - such is the power of Open Source where individuals see a need, solve it for themselves, and share it for the benefit of others.
While we’re cleaning up everything, leave no stones unturned. Spring clean time - it’s that time of year DownUnda.
One of the two threads on the subject has a detailed write up buried deep in there. I expect the mods and the author might collaborate to fork it out to a how-to guide for those that need it, and the two HACS addons may become rationalised or forked to yet another that is tuned to the needs of HomeAssistant users. Are you sure you need to maintain such an elaborate scheme, just to preserve your long term statistics, and from what I understand, currently outside the highly targeted backup scheme that has been devised specifically for HomeAssistant?
This is the strength of databases, where a clearly defined API and a solid interface layer should make the background database engine entirely transparent. You issue a data request, and your answer comes back, from whatever source is hiding underneath. Each database has their strength and weaknesses, the speed offset by robustness on some, and flexibility with querying on others. That you can pick and choose at whim (nearly) just shows how well the layered concept has progressed.
Look at your dashboards. Look at the data portrayed. Other than the WAF factor, is the existing functionality internal to HomeAssistant able to do the job, and you can shed even some more add-on overload?
My general feeling is that I don’t need the Grafana now. I started using it when HA did not give me what I wanted in long term stats. I had issues with a fridge freezer that was not cooling to the required -18degrees… Anyway long story short having the long term data was enough to convince the service man and manufacturer that there indeed was a problem and I was able to claim a warranty and that saved me $1000!
Now that HA has much better LTS I think I can do without it and just use HA.
I will ponder on it for a bit as I am on generator power at the moment as ERGON has a 6 hour planned power outage while they do some maintenance work.
Are there any procedures or best practises to follow in uninstalling Influx DB and Grafana from mys system??
Not really, they’ve already gone! You didn’t get much say in that.
If you have any incomplete references from dashboards etc, Spook will detect them and have a grumble.
Hope your generator power is smooth and has no spikes, and nothing gets interrupted when switchover happens.
Generator is a Sinewave 4500W Honda Inverter and have had it for a while. ALL my IT gear is on a UPS and that UPS has an autonomy time of about 20mins. I deliberately over spec’ed it. The UPS keeps it all on line. Change over is about 4ms from loss of mains. When genny is up it goes back to normal.
Here is a description of howto secure various data-set recorded/stored as long-term.
OK I have decided that I just want HA what are my next steps?
As you can see Grafana and InfluxDB are still running in my APPS.
What are the steps I need to take?
Do I do the Repair?
Selecting Submit will uninstall the app and permanently delete everything in its private data folder, including any databases, credentials and other internal state it kept there. Create a backup first if you might need that data later.
- Do a backup
- Select submit
- Stop Grafana
- Uninstall Grafana
Please confirm these steps or improve on them as I am lost here.
I just want a simple HA to manage as it’s becoming too much maintenance for me
I have now uninstalled InfluxDB and Grafana and now just relying on HA LTS. I have pushed the retention time out to 14 days so that I have a little better retention of data.
I am not sure what my long term needs are now but I was not prepared to go down that InfluxDB and Grafana path any more.
Time will tell and if anyone else has some experience in this please let me know what you experience was.
I just did an automatic backup and the file size dropped from 4.8GB to 353KB and backup time to my system and NAS was really quick now so that’s a plus
I have now done all updates and reconfigured my MQTT broker for pool water temperature monitoring. So Far ..So Good.
LTS seems to satisfy my needs now. Excellent!
