I recently upgraded from 115.2 to 117.0 (and then 117.2 today). Since the first upgrade, media_player.play_media has stopped working for my Squeezebox integration. I reverted back to 115.2 and everything works fine again.
To rule out a problem with my automation/script, I’ve tried calling the service from the dev tools and it fails there as well.
I checked the release notes and I don’t see anything Squeeze-specific mentioned. No breaking changes either.
I don’t see errors in HA’s logs, nor do I see any errors in the Squeeze server’s logs.
I have it installed, but I rarely use it. Usually, when I try to play through it, none of my radios are available. It’s on my (long) list of things I need to sort out.
You are right - I had used the wrong service . However, using media_player.play_media also works fine. I’m running Logitech Media Server Version: 8.0.0 - 1600604030
