Squeezebox configuration
Hey guys
I hope, i got the right category.
I’m trying to automate my squeezeboxes.
Home Assistant is installed as Core application on my Synology NAS.
I want to use a playlist from Spotify in LMS. LMS picks up the playlist, but the action goes into a loop and never finishes. Is there a way to integrate a timeout for this?
service: media_player.play_media
  entity_id: media_player.squeezebox_schlafzimmer
  media_content_id: "16171"
  media_content_type: playlist
metadata:
  title: "Spotify: Sleep lofi"
  thumbnail: null
  media_class: playlist
  children_media_class: track
  navigateIds:
    - media_content_type: Playlists
      media_content_id: Playlists
    - media_content_type: playlist
Second, I want to set the music to 18. But I think the parameters are delieverd wrong. Because I can set the sleep time, but that only has 1 parameter instead of 2 like the command mixer. Has anybody managed to set the volume on a Squeezebox? If so how?
Working sleep command:
service: squeezebox.call_method
  command: sleep
  parameters: 40
  entity_id:
    - media_player.squeezebox_schlafzimmer
Not working mixer command.
  command: mixer
  parameters: volume, 18
For anyone as dumb as I am, I found the solution.
Solution one, instead of using a playlist number from spotty, use the direct spotify link.
You can do this by taking the share link to a spotify playlist:
Sharelink: https://open.spotify.com/playlist/5FmmxErJczcrEwIFGIviYo?si=32df1d88089341a9
Link for LMS: 5FmmxErJczcrEwIFGIviYo (the part betweent playlist/ and the questionmark)
Setting up HA then looks like this:
action: squeezebox.call_method
  command: playlist
  parameters:
    - play
    - spotify:playlist:5FmmxErJczcrEwIFGIviYo
Solution 2:
Instead of using a comma to sperate the parameters, you have to to set them up like this:
  command: mixer
  parameters:
    - volume
    - 18
