Squeezebox skript Invalid data for call_service at pos 1 please help!
Hi everyone,
I have the following problem with the script for the squeezebox.
When I select player Garage and Laptop everything works.
In the Küche and TV I get the following error message.
Why does 2 out of 4 players work?
I would be grateful to you for the help.
Logger: homeassistant
Source: core.py:1449
First occurred: 16:16:25 (5 occurrences)
Last logged: 16:16:27
Error doing job: Task exception was never retrieved
File “/usr/src/homeassistant/homeassistant/components/script/init.py”, line 403, in _async_run
return await self.script.async_run(script_vars, context)
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 1260, in async_run
await asyncio.shield(run.async_run())
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 363, in async_run
await self._async_step(log_exceptions=False)
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 381, in _async_step
await getattr(self, handler)()
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 584, in _async_call_service_step
await service_task
File “/usr/src/homeassistant/homeassistant/core.py”, line 1449, in async_call
processed_data = handler.schema(service_data)
File “/usr/local/lib/python3.9/site-packages/voluptuous/schema_builder.py”, line 272, in call
return self._compiled([], data)
File “/usr/local/lib/python3.9/site-packages/voluptuous/validators.py”, line 215, in _run
return self._exec(self._compiled, value, path)
File “/usr/local/lib/python3.9/site-packages/voluptuous/validators.py”, line 341, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File “/usr/local/lib/python3.9/site-packages/voluptuous/validators.py”, line 339, in _exec
v = func(path, v)
File “/usr/local/lib/python3.9/site-packages/voluptuous/schema_builder.py”, line 817, in validate_callable
return schema(data)
File “/usr/local/lib/python3.9/site-packages/voluptuous/schema_builder.py”, line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File “/usr/local/lib/python3.9/site-packages/voluptuous/schema_builder.py”, line 432, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: not a valid value for dictionary value @ data[‘entity_id’]
Logger: homeassistant.components.script.play_squeezebox_radio
Source: helpers/script.py:1382
Integration: Skript (documentation, issues)
Select Radio Squeezebox: Error executing script. Invalid data for call_service at pos 1: not a valid value for dictionary value @ data[‘entity_id’]
input_number:
  initial_volume_radio:
    initial: 0.3
    min: 0
    max: 1
    step: 0.05
input_select:
  chromecast_radio_station:
    name: 'Select Radio Station'
    options:
      - ProFM
      - KissFM
      - EuropaFM
      - DigiFM
      - RadioZu
      - WefunkRadio
      - FunkRadio
      - Popular
      - MagicFM
      - VirginRadio
  chromecast_radio_speakers:
    name: 'Select Speakers'
    options:
      - Garage
      - Küche
      - TV
      - Laptop
script:
  play_squeezebox_radio:
    alias: Select Radio Squeezebox
    icon: mdi:radio
    sequence:
      - service: media_player.volume_set
        data_template:
          entity_id: >
            {% if is_state("input_select.chromecast_radio_speakers", "Garage") %} media_player.garage
            {% elif is_state("input_select.chromecast_radio_speakers", "Küche") %} media_player.kuche
            {% elif is_state("input_select.chromecast_radio_speakers", "TV") %} media_player.tv_samsung_6_series_55
            {% elif is_state("input_select.chromecast_radio_speakers", "Laptop") %} media_player.laptop
            {% endif %}
          volume_level: '{{  states("input_number.initial_volume_radio")  }}'
      - service: squeezebox.call_method
        data_template:
          entity_id: media_player.{{states.input_select.chromecast_radio_speakers.state}}
          command: favorites
          parameters: >
            {% if is_state('input_select.chromecast_radio_station', 'ProFM') %}
              ["playlist", "play", "item_id:0"]
            {% elif is_state('input_select.chromecast_radio_station', 'KissFM') %}
              ["playlist", "play", "item_id:1"]
            {% elif is_state('input_select.chromecast_radio_station', 'EuropaFM') %}
              ["playlist", "play", "item_id:2"]
            {% elif is_state('input_select.chromecast_radio_station', 'RadioZu') %}
              ["playlist", "play", "item_id:3"]
            {% elif is_state('input_select.chromecast_radio_station', 'DigiFM') %}
              ["playlist", "play", "item_id:4"]
            {% elif is_state('input_select.chromecast_radio_station', 'MagicFM') %}
              ["playlist", "play", "item_id:5"]
            {% elif is_state('input_select.chromecast_radio_station', 'VirginRadio') %}
              ["playlist", "play", "item_id:6"]
            {% elif is_state('input_select.chromecast_radio_station', 'Popular') %}
              ["playlist", "play", "item_id:7"]
            {% elif is_state('input_select.chromecast_radio_station', 'WefunkRadio') %}
              ["playlist", "play", "item_id:8"]
            {% elif is_state('input_select.chromecast_radio_station', 'FunkRadio') %}
              ["playlist", "play", "item_id:9"]
            {% endif %}
  stop_squeezebox_radio:
    alias: Stop Radio Squeezebox
    icon: mdi:radio
    sequence:
      - service: media_player.turn_off
        data_template:
          entity_id: >
            {% endif %}
