The arduino esp8266 library documentation is here http://arduino-esp8266.readthedocs.io/en/latest/index.html
But I haven’t seen anything that could change the power output. I think you probably need to change the configuration of your router to change the channel.
My code is based on an early version of what became the OpenMQTTGateway. I have added my own motion and light sensor, and a notification to simple push if it detects the broker has gone down. But the wifi setup is all the standard stuff you can find all over the internet.
433toMQTTto433 - ESP8266 program for home automation
Act as a wifi gateway between your 433mhz nodes and a MQTT broker
Send and receiving command by MQTT
This program enables to:
- receive MQTT data from a topic and send RF 433Mhz signal corresponding to the received MQTT data
- publish MQTT data to a different topic related to received 433Mhz signal
Contributor:
- 1technophile
Based on:
- MQTT library (https://github.com/knolleary)
- RCSwitch (https://github.com/sui77/rc-switch)
- ESP8266Wifi
Project home: https://github.com/1technophile/433toMQTTto433_ESP8266
Blog, tutorial: http://1technophile.blogspot.com/2016/09/433tomqttto433-bidirectional-esp8266.html
Permission is hereby granted, free of charge, to any person obtaining a copy of this software
and associated documentation files (the "Software"), to deal in the Software without restriction,
including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense,
and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so,
subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED
TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Some usefull commands to test gateway with mosquitto:
Subscribe to the subject for data receiption from RF signal
mosquitto_sub -t home/433toMQTT
Send data by MQTT to convert it on RF signal
mosquitto_pub -t home/MQTTto433/ -m 1315153
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <RCSwitch.h> // library for controling Radio frequency switch
#include <ESP8266mDNS.h>
#include <Simplepush.h>
#include "secrets.h"
RCSwitch mySwitch = RCSwitch();
Simplepush simple;
//Do we want to see trace for debugging purposes
#define TRACE 1 // 0= trace off 1 = trace on
// Update these with values suitable for your network.
//variables to avoid duplicates
#define time_avoid_duplicate 1500 // if you want to avoid duplicate mqtt message received set this to > 0, the value is the time in milliseconds during which we don't publish duplicates
// array to store previous received RFs codes and their timestamps
long ReceivedRF[10][2] ={{0,0},{0,0},{0,0},{0,0},{0,0},{0,0},{0,0},{0,0},{0,0},{0,0}};
#define subjectMQTTtoX "home/commands/#"
//RF MQTT Subjects
#define subject433toMQTT "home/433toMQTT"
#define subjectMQTTto433 "home/MQTTto433/"
#define SUBJECTSIMPLEPUSHKEY "simplepush/key"
//adding this to bypass to problem of the arduino builder issue 50
void callback(char*topic, byte* payload,unsigned int length);
WiFiClient wifiClient;
// mqttClient parameters
PubSubClient mqttClient(wifiClient);
//MQTT last attemps reconnection number
unsigned long lastReconnectAttempt = 0;
unsigned long reconnectStart = 0;
unsigned long lastDarkMessage = 0;
bool noticeSent = false;
bool firsttime = true;
char simplepush_key[128];
char simplepush_title[128] = "MQTT Broker Inaccessible";
char simplepush_message[128] = "Cannot connect to MQTT broker";
char simplepush_event[128] = "Failure";
// Motion Sensor Pin
const int MOTIONSENSORPIN = D1; // D5 on NodeMCU is GPIO14 on 202
boolean motionDetected = false;
const int LIGHT_LEVEL_PIN = D8;
boolean lightlevel = false;
// Callback function, when the gateway receive an MQTT value on the topics subscribed this function is called
void callback(char* topic, byte* payload, unsigned int length) {
// In order to republish this payload, a copy must be made
// as the orignal payload buffer will be overwritten whilst
// constructing the PUBLISH packet.
trc("Hey I got a callback ");
if (memcmp(topic, SUBJECTSIMPLEPUSHKEY, strlen(SUBJECTSIMPLEPUSHKEY)) == 0) {
// Update push key with new value
int tocopy = std::min((unsigned int)127, length);
memcpy(simplepush_key, payload, tocopy);
simplepush_key[tocopy] = '\0';
trc("Simplepush key is now ");
trc(simplepush_key);
return;
// Allocate the correct amount of memory for the payload copy
byte* p = (byte*)malloc(length);
// Copy the payload to the new buffer
memcpy(p,payload,length);
// Conversion to a printable string
p[length] = '\0';
String callbackstring = String((char *) p);
String topicNameRec = String((char*) topic);
//launch the function to treat received data
receivingMQTT(topicNameRec,callbackstring);
// Free the memory
free(p);
void setup()
//Launch serial for debugging purposes
Serial.begin(115200);
//Begining wifi connection
setup_wifi();
delay(1500);
strncpy(simplepush_key, DEFAULT_SIMPLEPUSH_KEY, 128);
//mySwitch.enableTransmit(4); // RF Transmitter is connected to Pin D2
//mySwitch.setRepeatTransmit(20); //increase transmit repeat to avoid lost of rf sendings
mySwitch.enableReceive(digitalPinToInterrupt(D2)); // Receiver on NodeMCU pin D2 -- GPIO 5 on 202
pinMode(MOTIONSENSORPIN, INPUT);
mqttClient.setCallback(callback);
if (!MDNS.begin("MQTTto433")) {
trc("Error setting up MDNS responder");
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
trc("Connecting to ");
trc(wifi_ssid);
WiFi.begin(wifi_ssid, wifi_password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
trc(".");
trc("WiFi connected");
boolean reconnect() {
// Loop until we're reconnected
if (!mqttClient.connected()) {
firsttime = true;
if (MDNS.queryService("mqtt", "tcp") > 0) {
mqttClient.setServer(MDNS.IP(0), MDNS.port(0));
trc("Attempting MQTT connection...");
// Attempt to connect
if (mqttClient.connect("433toMQTTto433", "sensor/433/status", 1, true,
"offline")) {
// Once connected, publish an announcement...
mqttClient.publish("sensor/433/status","online", true);
trc("connected");
//Subscribing to topic(s)
//subscribing(subjectMQTTtoX);
if (!mqttClient.subscribe(SUBJECTSIMPLEPUSHKEY)) {
trc("Couldn't subscribe to simplepush_key");
} else {
trc("failed, rc=");
trc(String(mqttClient.state()));
} else {
trc("No MQTT services found");
return mqttClient.connected();
void loop()
unsigned long now = millis();
//MQTT mqttClient connexion management
if (now - lastReconnectAttempt > 5000) {
lastReconnectAttempt = now;
if (!noticeSent && reconnectStart == 0) {
reconnectStart = millis();
trc("mqttClient mqtt not connected, trying to connect");
// Attempt to reconnect
if (reconnect()) {
reconnectStart = 0;
noticeSent = false;
} else if (!noticeSent && ((now - reconnectStart) > 60000)) {
trc("Sending alert");
simple.send(simplepush_key, simplepush_title,
simplepush_message, simplepush_event);
noticeSent = true;
} else {
// MQTT loop
mqttClient.loop();
// Receive loop, if data received by RF433 send it by MQTT to subject433toMQTT
if (mySwitch.available()) {
// Topic on which we will send data
trc("Receiving 433Mhz signal");
unsigned long MQTTvalue;
MQTTvalue=mySwitch.getReceivedValue();
mySwitch.resetAvailable();
if (mqttClient.connected()) {
if (!isAduplicate(MQTTvalue)) {// conditions to avoid duplications of RF -->MQTT
//trc("Sending 433Mhz signal to MQTT");
//trc(String(MQTTvalue));
switch (MQTTvalue) {
case 4000398: // rc button 1 off
sendMQTT("/energenie/ENER002/444102/2", "OFF", true);
break;
case 4000399: // rc button 1 on
sendMQTT("/energenie/ENER002/444102/2", "ON", true);
break;
case 4000390: // rc button 2 off
sendMQTT("/energenie/ENER002/444102/3", "OFF", true);
break;
case 4000391: // rc button 2 on
sendMQTT("/energenie/ENER002/444102/3", "ON", true);
break;
case 4000394: // rc button 3 off
sendMQTT("/energenie/ENER002/444102/4", "OFF", true);
break;
case 4000395: // rc button 3 on
sendMQTT("/energenie/ENER002/444102/4", "ON", true);
break;
case 4000386: // rc button 4 off
break;
case 4000387: // rc button 4 on
break;
case 4000396: // rc button all off
break;
case 4000397: // rc button 4 on
break;
default:
sendMQTT(subject433toMQTT,String(MQTTvalue), false);
storeValue(MQTTvalue);
} else {
if (reconnect()) {
trc("Sending 433Mhz signal to MQTT after reconnect");
//Light level
// Only send once a second to avoid spamming when light
// level is on the limit
if (now < lastDarkMessage // Check for wrap around
now > (lastDarkMessage + 1000)
|| firsttime == true) {
boolean currentLight = (digitalRead(LIGHT_LEVEL_PIN) == HIGH);
if (lightlevel && !currentLight) {
sendMQTT("sensor/433/dark", "OFF", false);
lightlevel = currentLight;
lastDarkMessage = now;
} else if (!lightlevel && currentLight) {
sendMQTT("sensor/433/dark", "ON", false);
} else if (firsttime == true) {
sendMQTT("sensor/433/dark", currentLight?"ON":"OFF", false);
// Moton Detection
boolean currentMotion = (digitalRead(MOTIONSENSORPIN) == HIGH);
if (motionDetected && !currentMotion) {
sendMQTT("sensor/433/motion", "OFF", false);
motionDetected = currentMotion;
} else if (!motionDetected && currentMotion) {
sendMQTT("sensor/433/motion", "ON", false);
sendMQTT("sensor/433/motion", currentMotion?"ON":"OFF", false);
firsttime = false;
void storeValue(long MQTTvalue){
// find oldest value of the buffer
int o = getMin();
trc("Minimum index: " + String(o));
// replace it by the new one
ReceivedRF[o][0] = MQTTvalue;
ReceivedRF[o][1] = now;
trc("send this code :" + String(ReceivedRF[o][0])+"/"+String(ReceivedRF[o][1]));
trc("Col: value/timestamp");
for (int i = 0; i < 10; i++)
trc(String(i) + ":" + String(ReceivedRF[i][0])+"/"+String(ReceivedRF[i][1]));
int getMin()
int minimum = ReceivedRF[0][1];
int minindex=0;
if (ReceivedRF[i][1] < minimum) {
minimum = ReceivedRF[i][1];
minindex = i;
return minindex;
boolean isAduplicate(long value){
trc("isAduplicate");
// check if the value has been already sent during the last "time_avoid_duplicate"
for (int i=0; i<10;i++){
if (ReceivedRF[i][0] == value){
if (now - ReceivedRF[i][1] < time_avoid_duplicate){
trc("don't send this code :" + String(ReceivedRF[i][0])+"/"+String(ReceivedRF[i][1]));
return true;
return false;
void subscribing(String topicNameRec){ // MQTT subscribing to topic
char topicStrRec[26];
topicNameRec.toCharArray(topicStrRec,26);
// subscription to topic for receiving data
boolean pubresult = mqttClient.subscribe(topicStrRec);
if (pubresult) {
trc("subscription OK to");
trc(topicNameRec);
void receivingMQTT(String topicNameRec, String callbackstring) {
trc("Receiving data by MQTT");
trc(topicNameRec);
char topicOri[26] = "";
char topicStrAck[26] = "";
char datacallback[26] = "";
// Below you send RF signal following data value received by MQTT
callbackstring.toCharArray(datacallback,26);
trc(datacallback);
long int data = atol(datacallback);
trc("Send received data by RF 433");
trc(String(data));
//send received MQTT value by RF signal (example of signal sent data = 5264660)
mySwitch.send(data, 24);
//send MQTT data dataStr to topic topicNameSend
void sendMQTT(String topicNameSend, String dataStr, boolean retain){
char topicStrSend[100];
topicNameSend.toCharArray(topicStrSend,100);
char dataStrSend[200];
dataStr.toCharArray(dataStrSend,200);
boolean pubresult = mqttClient.publish(topicStrSend,dataStrSend, retain);
trc("sending ");
trc(dataStr);
trc("to ");
trc(topicNameSend);
//trace
void trc(String msg){
if (TRACE) {
Serial.println(msg);
/* vim: set expandtab shiftwidth=2 tabstop=2: */
