So, I started with RaspbeeII on my PI4-8. There was a struggle to get it working ZHA, but eventually it worked. I haven’t got to many devices yet, 20-ish.
But during Mars and April I had to setup the network again, because it lost all devices.
And the last time I could not setup it at all.
Then I tried Z2M, same thing. Then I bought me a ConBee II, same thing. Connected the ConBee II with a 60 cm usb cable, No success! Added another 1.8 meter and it started !
Pairing went like a treat!
But I have got a bunch of sr-zgp2801k2-dim and sr-zgp2801k4-dim from Sunricher, they show up, but as “Not supported”. Looking into it, it looks like they is supported since 1.22.1. According to HA the zigbee2mqtt I’m running is 1.25.1-1.
I also have two wall mounted remotes from Dresden Elektronik, they don’t show up at all.
This can be due to the fact that I’m running on channel 15.
Uh, too tired I think I have mixed them up, but I’m not sure. I’ll be back after work…
Much struggle with this, but I think I have found a solution!
Found this link.
And it looks like the wall transmitters can have different ieee-adresses.
The one in the implemetation is /^0x00000000010…$/, mine is /^0x00000000021…$/.
I have now implemented an external converter. But it didn’t work to add in configuration.yaml, I had to do it via the UI.
Now I have to see if it works, I don’t have 40km long arms !
I got them here https://www.m.nu/
I also think that Sunricher sells them aswell.
If I remember correctly they also exist in a version that won’t pair with Z2M.
Also you may have to add their address…
