Can you log into your SRP account and then go to this URL but replace the 99999999 billAccount value with your account number? (No leading zero, no dashes).
The rate column indicates whether the power usage was consumed off-peak or on-peak. Maybe the designer of the component is using a standard plan instead of the EZ-3 plan and doesn’t receive that column in his data?
