Hi, Home Assistant 2023.4.5, Supervisor 2023.04.0, Operating System 10.0, Frontend 20230411.1 - latest running on Rpi4.
“Move data disk” concludes (I am able to select my 120GB SSD fine) --and nothing happens. Everything is still on the SD card. Storage is still displaying 80% full, same as before (it’s a 32GB SD card). I can pick my SSD in the migration dialogue again.
I don’t see anything in log. What to check? Thanks.
This is “sda” in Hardware - All devices:
`/dev/disk/by-id/ata-Patriot_Burst_E0CD0799032200919475`
DEVLINKS: >-
/dev/disk/by-diskseq/29 /dev/disk/by-id/ata-Patriot_Burst_E0CD0799032200919475
/dev/disk/by-id/usb-ASMT_2115_1234567923CE-0:0
/dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1:1.0-scsi-0:0:0:0
DEVNAME: /dev/sda
DEVPATH: >-
/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb2/2-1/2-1:1.0/host0/target0:0:0/0:0:0:0/block/sda
DEVTYPE: disk
DISKSEQ: '29'
ID_ATA: '1'
ID_ATA_DOWNLOAD_MICROCODE: '1'
ID_ATA_FEATURE_SET_HPA: '1'
ID_ATA_FEATURE_SET_HPA_ENABLED: '1'
ID_ATA_FEATURE_SET_PM: '1'
ID_ATA_FEATURE_SET_PM_ENABLED: '1'
ID_ATA_FEATURE_SET_SECURITY: '1'
ID_ATA_FEATURE_SET_SECURITY_ENABLED: '0'
ID_ATA_FEATURE_SET_SECURITY_ENHANCED_ERASE_UNIT_MIN: '60'
ID_ATA_FEATURE_SET_SECURITY_ERASE_UNIT_MIN: '20'
ID_ATA_FEATURE_SET_SMART: '1'
ID_ATA_FEATURE_SET_SMART_ENABLED: '1'
ID_ATA_ROTATION_RATE_RPM: '0'
ID_ATA_SATA: '1'
ID_ATA_SATA_SIGNAL_RATE_GEN1: '1'
ID_ATA_SATA_SIGNAL_RATE_GEN2: '1'
ID_ATA_WRITE_CACHE: '1'
ID_ATA_WRITE_CACHE_ENABLED: '1'
ID_BUS: ata
ID_MODEL: Patriot_Burst
ID_MODEL_ENC: >-
Patriot\x20Burst\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20
ID_PART_TABLE_TYPE: gpt
ID_PART_TABLE_UUID: 3314cda2-5b76-46c1-a455-ae9dff8d7187
ID_PATH: platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1:1.0-scsi-0:0:0:0
ID_PATH_TAG: platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_1_0-scsi-0_0_0_0
ID_REVISION: SBFM61.3
ID_SERIAL: Patriot_Burst_E0CD0799032200919475
ID_SERIAL_SHORT: E0CD0799032200919475
ID_TYPE: disk
ID_USB_DRIVER: usb-storage
ID_USB_INSTANCE: '0:0'
ID_USB_INTERFACES: ':080650:080662:'
ID_USB_INTERFACE_NUM: '00'
ID_USB_MODEL: '2115'
ID_USB_MODEL_ENC: 2115\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20\x20
ID_USB_MODEL_ID: 55aa
ID_USB_REVISION: '0'
ID_USB_SERIAL: ASMT_2115_1234567923CE-0:0
ID_USB_SERIAL_SHORT: 1234567923CE
ID_USB_TYPE: disk
ID_USB_VENDOR: ASMT
ID_USB_VENDOR_ENC: ASMT\x20\x20\x20\x20
ID_USB_VENDOR_ID: 174c
MAJOR: '8'
MINOR: '0'
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: '4739905'
sda1
/dev/disk/by-id/ata-Patriot_Burst_E0CD0799032200919475-part1
system
timer
ttyAMA0
ttyUSB0
/dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_22_98_A6_AC-if00-port0
tun
urandom
usb1
usb2
vc-mem
vcio
vcsm-cma
vga_arbiter
vchiq
video10
video11
video12
video13
video14
video15
video16
video18
video19
video20
video21
video22
video23
video31
watchdog
watchdog0
zero
and this is sda1:
DEVLINKS: >-
/dev/disk/by-id/usb-ASMT_2115_1234567923CE-0:0-part1
/dev/disk/by-label/hassos-data /dev/disk/by-partlabel/hassos-data-external
/dev/disk/by-partuuid/bc3d35e3-8fb5-49a8-b0ce-698d820514a2
/dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1:1.0-scsi-0:0:0:0-part1
/dev/disk/by-uuid/34eda77e-f37e-4ae6-a2df-049cb858f8e3
DEVNAME: /dev/sda1
DEVPATH: >-
/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb2/2-1/2-1:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1
DEVTYPE: partition
DISKSEQ: '29'
ID_ATA: '1'
ID_ATA_SATA: '1'
ID_BUS: ata
ID_FS_LABEL: hassos-data
ID_FS_LABEL_ENC: hassos-data
ID_FS_TYPE: ext4
ID_FS_USAGE: filesystem
ID_FS_UUID: 34eda77e-f37e-4ae6-a2df-049cb858f8e3
ID_FS_UUID_ENC: 34eda77e-f37e-4ae6-a2df-049cb858f8e3
ID_FS_VERSION: '1.0'
ID_MODEL_ENC: >-
ID_PART_ENTRY_DISK: '8:0'
ID_PART_ENTRY_NAME: hassos-data-external
ID_PART_ENTRY_NUMBER: '1'
ID_PART_ENTRY_OFFSET: '2048'
ID_PART_ENTRY_SCHEME: gpt
ID_PART_ENTRY_SIZE: '234438656'
ID_PART_ENTRY_TYPE: 0fc63daf-8483-4772-8e79-3d69d8477de4
ID_PART_ENTRY_UUID: bc3d35e3-8fb5-49a8-b0ce-698d820514a2
ID_TYPE: disk
ID_USB_TYPE: disk
ID_USB_VENDOR: ASMT
MAJOR: '8'
MINOR: '1'
PARTN: '1'
PARTNAME: hassos-data-external
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: '4924616'
