SSD1306 OLED display Change content via Home Assistant?
I have connected an OLED display (SSD1306) to my NodeMCU ESP8266; there is also a button on it with which you can switch between different “pages”.
For example, there is the “Outside” page to display the temperature outside.
My question would be whether there are any (concrete) code examples or ideas on how I need to change the code so that I can use a new entity (e.g. select.X) in HomeAssistant to select what is displayed on the screen on the “Outside” page.
Best regards and thanks for your reply!
This is my code so far:
substitutions:
  friendly_name: ESPHome
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: false
  project:
    version: '1.0'
esp8266:
  board: nodemcuv2  # Change the board type to nodemcuv2 for NodeMCU 0.1
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
  ssid: "ssid"
  password: "password"
  ap:
    ssid: "Display"
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
font:
  - file: "gfonts://Roboto"
i2c:
  sda: D1
  scl: D2
  - platform: homeassistant
    entity_id: sensor.time
    name: "Wetterstation Temperature"
    entity_id: sensor.unknown_70_ee_50_a2_17_9a_unknown_70_ee_50_a2_17_9a_unknown_70_ee_50_a2_17_9a_aussenmodul_temperature
    name: "Wetterstation Humidity"
    entity_id: sensor.unknown_70_ee_50_a2_17_9a_unknown_70_ee_50_a2_17_9a_unknown_70_ee_50_a2_17_9a_aussenmodul_humidity
    name: "Wohnzimmer Temperature"
    entity_id: sensor.wohnzimmer_temperatur
    name: "Wohnzimmer Humidity"
    entity_id: sensor.wohnzimmer_luftfeuchtigkeit
globals:
  - id: display_temperature
    type: bool
    restore_value: true
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
    #  - delayed_off: 1ms
    on_press:
      then:
        - globals.set:
            value: !lambda "return !id(display_temperature);"
        - if:
            condition:
              lambda: "return id(display_temperature);"
            then:
              - display.page.show: weather_outdoor_page
            else:
              - display.page.show: weather_indoor_page
    on_double_click:
      then:
        - display.page.show: hello_page
time:
    timezone: Europe/Amsterdam
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    reset_pin: D0
    address: 0x3C
    pages:
      - id: weather_outdoor_page
        lambda: |-
          if (id(display_temperature)) {
            char str[17];
            time_t currTime = id(homeassistant_time).now().timestamp;
            strftime(str, sizeof(str), "%H:%M  Aussen", localtime(&currTime)); // Nur Uhrzeit anzeigen
            it.printf(0, 0, id(roboto_small), "%s", str); // Anzeige der Uhrzeit
            it.printf(0, 20, id(roboto), "%.1f°C", id(Temperature).state); // Display temperature
            it.printf(0, 40, id(roboto), "%.1f %%", id(Humidity).state); // Display humidity
      - id: weather_indoor_page
        lambda: |-
          char str[17];
          strftime(str, sizeof(str), "%H:%M  Innen", localtime(&currTime)); // Nur Uhrzeit anzeigen
          it.printf(0, 20, id(roboto), "%.1f°C", id(Wohnzimmer_Temperature).state); // Display temperature
          it.printf(0, 40, id(roboto), "%.1f %%", id(Wohnzimmer_Humidity).state); // Display humidity
      - id: hello_page
        lambda: |-
          it.printf(0, 0, id(roboto), "Hello!");
select:
  • platform: template
    optimistic: true
    options:
    • Main
    • Page 2
    • Page 3
    • Page 4
      initial_option: Main
      on_value:
    • if:
      condition:
      lambda: ‘return id(my_select).state == “Main”;’
      then:
      - logger.log: “Main page selected”
      - display.page.show: page1
    • if:
      condition:
      lambda: ‘return id(my_select).state == “Page 2”;’
      then:
      - logger.log: “Page 2 selected”
      - display.page.show: page2
    • if:
      condition:
      lambda: ‘return id(my_select).state == “Page 3”;’
      then:
      - logger.log: “Page 3 selected”
      - display.page.show: page3
    • if:
      condition:
      lambda: ‘return id(my_select).state == “Page 4”;’
      then:
      - display.page.show: page4
entity id-s can’t be changed at runtime, so your best chance is creating a template sensor in home assistant, updating it when needed (in HA), and using that in your display page.
but if your question was how to change the page, here’s what i use all over:
display:
  - platform: ssd1306_i2c # https://esphome.io/components/display/ssd1306
    address: 0x3C
    id: lcd  # https://www.aliexpress.com/item/32861875681.html
    model: "SSD1306 128x64" # SSD1306 with 128 columns and 64 rows
    update_interval: 0s
    auto_clear_enabled: false
    invert: false
    rotation: 0°
    contrast: 50%
    flip_x: true
    flip_y: true
    pages:
      - id: page_idle
        lambda: |-
select:
    icon: mdi:book-open-page-variant-outline
    entity_category: config
    update_interval: never
    disabled_by_default: true
    lambda: |-
          auto page = id(lcd).get_active_page();
          std::string pagename;
          if (page == id(page_idle)) {
            pagename = "Idle";
          } else if (page == id(page_battery)) {
            pagename = "Charging";
          } else if (page == id(page_gyro)) {
            pagename = "Gyro";
          } else if (page == id(page_animation)) {
            pagename = "Animation";
          } else if (page == id(page_meta)) {
            pagename = "Meta";
          } else if (page == id(page_lost)){
            pagename = "Lost";
          } else if (page == id(page_motors)){
            pagename = "Motors";
          } else{
          return pagename;
    options:
      - "Idle"
      - "Charging"
      - "Meta"
      - "Gyro"
      - "Animation"
      - "Motors"
      - "Lost"
    set_action:
      then:
        - lambda: |-
            auto current_page = id(lcd).get_active_page();
            auto new_page = id(page_battery);
            if (x == "Idle") {
              new_page = id(page_idle);
            } else if (x == "Charging") {
            } else if (x == "Animation") {
              new_page = id(page_animation);
            } else if (x == "Meta") {
              new_page = id(page_meta);
            } else if (x == "Gyro") {
              new_page = id(page_gyro);
            } else if (x == "Motors") {
              new_page = id(page_motors);
            } else if (x == "Lost") {
              new_page = id(page_lost);
            else {
              ESP_LOGW("select","no index found for page");
            if(current_page!=new_page){
              id(lcd).update();
