Ssd1306 Screen ON/OFF time based
Hi I have a ssd1306 connected to a sensor and would like to now if the screen can be turned off say at 10pm to 6am the screen is going in a bedroom and I don’t want it going while trying to sleep ? if thats possibleThanks
So, you didn’t leave much information on your setup but this is how I would address your request. Assuming that you have a connection to HA, I would do the following.
Utilize the time: component to setup a 1 minute re-occurring event.
time:
  platform: homeassistant
  on_time:
    - seconds: 0
      then:
        lambda: |-
          static bool bDisplay = true;
          auto now = id(ha_time).now(); // local time
          if ((now.hour >= 22 || now.hour < 6) && bDisplay) {
            id(turn_display_off).execute();
            bDisplay = false;
          } else if ((now.hour >= 6 && now.hour < 22) && !bDisplay) {
            id(turn_display_on).execute();
            bDisplay = true;
The above code Is psuedo code-ish. I’m not claiming it will compile but it’s close. It appears your display has on/off commands 0xAE, 0xAF. They would be sent in the two scripts turn_display_off and turn_display_on. You could of course utilize the api: component to pull times from HA to make it more configurable. I utilize Lamba coding almost exclusively so there may be a way of doing the same thing in the scripting language as well. Hope this helps.
Hi thanks for your reply (sorry been late)
MY yaml file as below but i’m getting (below) while validating the code
INFO Reading configuration...
ERROR Error while reading config: Invalid YAML syntax. Please see YAML syntax reference or use an online YAML syntax validator:
mapping values are not allowed here
  in "/config/esphome/master_bedroom_sensor.yaml", line 143, column 10:
         then:
esphome:
  platform: ESP32
  board: esp-wrover-kit
wifi:
  ssid: "----"
  password: "-----"
  power_save_mode: none
  manual_ip:
#    # Set this to the IP of the ESP
    static_ip: 192.168.1.33
#    # Set this to the IP address of the router. Often ends with .1
    gateway: 192.168.1.1
#    # The subnet of the network. 255.255.255.0 works for most home networks.
    subnet: 255.255.255.0
    dns1: 192.168.1.12
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "----"
ota:
  password: "----"
esp32_ble_tracker:
  scan_interval: 60s
web_server:
  port: 80
text_sensor:
  - platform: wifi_info
    ip_address:
      name: "Master Bedroom Sensor IP address"
    ssid:
      name: "Master Bedroom Sensor SSID"
  - platform: version
    name: "Master Bedroom Sensor ESPHome Version"
apds9960:
  address: 0x39
  update_interval: 30s
switch:
  - platform: restart
    name: "Master Bedroom Sensor Restart"
  - platform: shutdown
    name: "Master Bedroom Sensor Shutdown"
binary_sensor:
  - platform: status
    name: "Master Bedroom Sensor Status"
  - platform: gpio
    pin: 34
    name: "Master Bedroom Motion"
    device_class: motion
  - platform: gpio
    pin: 33
    filters:
      - delayed_off: 6s
  - platform: ble_presence
    mac_address: ----
    mac_address: "----"
    mac_address: ----
  - platform: apds9960
    name: "APDS960 Up Movement"
    direction: UP
    name: "APDS960 Down Movement"
    direction: DOWN
    name: "APDS960 Left Movement"
    direction: LEFT
    name: "APDS960 Right Movement"
    direction: RIGHT
  - platform: wifi_signal
    name: "Master Bedroom Sensor WiFi Signal"
    update_interval: 60s
  - platform: bmp280
    temperature:
      name: "BME280 Temperature"
      oversampling: 16x
    pressure:
      name: "BME280 Pressure"
    address: 0x76
    name: "APDS9960 Clear Channel"
    type: CLEAR
    name: "APDS9960 Red Channel"
    type: RED
    name: "APDS9960 Green Channel"
    type: GREEN
    name: "APDS9960 Blue Channel"
    type: BLUE
    name: "APDS9960 Proximity Channel"
    type: PROXIMITY
  - platform: uptime
    name: Master Bedroom Uptime
time:
  - platform: homeassistant
    on_time:
  - seconds: 0
     then:
      lambda: |-
            bDisplay = false;
            bDisplay = true;};
display:
  - platform: ssd1306_i2c
    model: "SH1106 128x64"
    address: 0x3C
    lambda: |-
      // Print "Bedroom Sensor" in top center.
      it.printf(64, 0, id(font1), TextAlign::TOP_CENTER, "Bedroom Sensor");
      // Print Master Bedroom Temperature (from master_bedroom_sensor)
      if (id(mb_temp).has_state()) {
        it.printf(3, 60, id(font2), TextAlign::BASELINE_LEFT , "%.1f°", id(mb_temp).state);
      // Print Master Bedroom Pressure (from master_bedroom_sensor)
      if (id(mb_press).has_state()) {
        it.printf(127, 60, id(font3), TextAlign::BASELINE_RIGHT , "%.1f°", id(mb_press).state);
font:
  - file: 'slkscr.ttf'
  - file: 'BebasNeue-Regular.ttf'
  - file: 'arial.ttf'
i2c:
  sda: 21
  scl: 22
  scan: True
Yaml is very picky about indents and spaces.
time:
  - platform: sntp
    on_time:
      # Every 5 minutes
      - seconds: 0
        minutes: /5
        then:
          - switch.toggle: my_switch
I took this out of the documentation. Your time: code is not indented properly.
