SSD1309 display with ESPhome
I am trying to add SS1309 display to ESPhome using ESP32. I tried using this display with WLED but it only white noise on the display.
So I tired using ESPhome with following code and nothing seems to happen. OLED is not even powering up.
This is the code I am using
font:
 # gfonts://family[@weight]
  - file: "gfonts://Roboto"
# Example configuration entry
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
display:
  - platform: ssd1306_spi
    model: "SSD1306 128x64"
    cs_pin: GPIO15
    dc_pin: GPIO2
    reset_pin: GPIO4
    lambda: |-
      it.print(0, 0, id(roboto), "Hello World!");
output:
  - platform: gpio
    pin: GPIO33
switch:
  - platform: output
    output: 'generic_out'
I can’t understand this code, which is referenced here.
output:
  - platform: gpio
    pin: GPIO33
switch:
  - platform: output
Have you tried operating the Screen Enable switch?
If you’ve not connected the module to anything yet, try adding:
    restore_mode: ALWAYS_ON
to the switch definition (docs).
I did which GPIO I should use for the switch?
I am using these pins
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
 cs_pin: GPIO15
    dc_pin: GPIO2
    reset_pin: GPIO4
What screen and ESP hardware do you have: link? The code in the feature request is for a specific packaging of that display.
I have 2.42 SSD1309 OLED display, pics with WLED installed
Have you gotten anywhere with getting the SSD1309 to work? I’ve got the same issue.
I was the one who created that request.
The switch is something specific for the device I have. It power the screen throght GPIO33. I don’t think this is your case.
The only difference I see between your configuration and mine is the miso pin:
spi:
  clk_pin: 18
  mosi_pin: 23
  miso_pin: 32
display:
    cs_pin: 5
    dc_pin: 19
    reset_pin: 4
    lambda: |-
Not sure if it will help.
it is working for me on esphome.
