I have an problem with OLED display SSD1322 - blank bar and text mirrored:
Under arduino code with olikraus u8g2 driver I was found solution - in the file “u8x8_d_ssd1322.c” I corrected two positions:
- “default_x_offset” → form 0x01c to 0x018
- Second parameter of of init seq "U8X8_CAA(0xa0, 0x06, 0x011), /* Set Re-Map / Dual COM Line Mode /" → form 0x06 to 0x016.
So finally init seq is U8X8_CAA(0xa0, 0x016, 0x011), / Set Re-Map / Dual COM Line Mode */
After modyfied those two position now ssd1322 working very well.
Now question about ESPHome and driver for ssd1322 - what file and what parameters for ssd1322 ESPHome driver should I change - based on changes what I made at olikraus u8g2 driver?
Do sombody can support me?
Thank you.
