SSH add-on copy paste on a mac
I run the SSH & Web Terminal add-on and i’m wondering how i can copy something from the terminal into my clipboard. I’m working on a Mac and can’t seem to figure out how this can be done.
Any suggestions?
note: past something from the clipboard with cmd-v works.
You should just be able to highlight text in the terminal window and then copy with cmd-c. Alternatively, highlight the text and then hold ctrl and click the text, then select “copy” in the context menu that pops up
Unfortunately none of those work
A bit late here, but in case other are, like me, looking for a solution and find this post, I finally found a way to do it.
not the most elegant one, but cmd-a then cmd-c selects all the text in the terminal and copies it to clipboard. then paste it to any text editor, and select the needed bit as usual.
